Old 09-29-2006, 12:55 AM
w_hodel's Avatar
w_hodel w_hodel is offline
Send a message via AIM to w_hodel Send a message via MSN to w_hodel Send a message via Yahoo to w_hodel
Question Brake System
Hey guys I just got new Stainless steel braided lines, rotors, etc.. for my stealth which I am in the middle of an engine rebuild. I wanted to flush out the brake system and put Dot 4 into it, or at least flush it and put Dot3. Any suggestions as to put Dot 4 or Dot 3? Also, any suggestions or cautions when I flush out the system? Any help would be welcome, thanks.
1991 Dodge Stealth R/T NA ATX
Dual Exaust w/12" Glass Packs
3SX Downpipe
Magnaflow High Flow Cat
Alpine Deck, Alpine Speakers
2 - JL W3 10" Subs w/JL 500w Amp
PS2, 7" Flip Down Screen
6-Disc CD Changer
Sound Dampening Spray all throughtout Interior (Huge Difference!)
Sunroof (installed soon)
3SX Aluminum Crank Pulley, 3rd Gen Lifters
Aluminum Intake Pipe w/Matrix Air Filter
2002 Ford Ranger XLT Ext Cab 3.0 V6
Old 09-29-2006, 03:01 AM
Igovert500's Avatar
blue + red light magnet
Re: Brake System
I've heard good things about Motul RBF 600 and ATE Super Blue, stick with a DOT 4.
3sx has speed bleeders which make it much simpler to bleed the brakes on your own, without the help of a partner. Other than that, it's pretty much just like bleeding any other car.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-02-2006, 03:43 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Brake System
Originally Posted by w_hodel
...any suggestions or cautions when I flush out the system?.
yea. don't get any on your freaking paint!
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-03-2006, 01:27 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Brake System
another helpful hint: when bleeding each brake, put about 1 foot of clear rubber tubing over the nipple and going down into a bucket. it will help keep the messy brake fluid off your hands.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-05-2006, 11:03 PM
w_hodel's Avatar
Re: Brake System
Thank you much for all your advice, I appreciate it!
3SX Downpipe
6-Disc CD Changer
