Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 09-28-2006, 11:43 PM
lilmike571 lilmike571 is offline
Exclamation 89 ford bronco will not start need help!!!
I have a 89 ford bronco(full size) with a 351 wendsor. i just put the motor back in with a new oil pump. it will run fine as long as u are pooring gas in the intake and dies when that gas burns off. i get gas to the fuel rail but not in the engine. could it be my injectors?? the motor saet up for approx 5 months and was running fine befor other than the oil pump any suggestions??
Old 09-29-2006, 04:00 AM
Pete33Vt Pete33Vt is offline
Re: 89 ford bronco will not start need help!!!
Could be your pressure regulator. Also check all the wires going to your injectors, one might have gotten broke in engine removal.
Old 09-29-2006, 01:29 PM
thanks i will check that
Old 11-08-2006, 09:06 PM
rhandwor rhandwor is offline
Use a noid light and check for power to the injectors. It is also possible to plug them into the wrong injector check the injector color code in the wiring diagram. Also use a gage and check for proper pressure. Make sure the ground wire is connected for the computer system.
