Good truck or Bad truck??
Well, i really like what i see when i go look at the 98 sierras.....i would personally like 4.3L ones and im sure thinking about buying one within the next 2 months....anybody think that it it not a good truck to buy? Is there alot of problems with them? How hard are they to work on yourself?
any comments should help Thx, Rob |
Re: Good truck or Bad truck??
You are asking a pretty big question because what could be a problem for you with a truck might not be for someone else. I have saved thousands of dollars by reading the posts here and on the Silverado forum. You should look there also because they are really the same truck, just different sheet metal. I have a 2000 Silverado 5.3 myself and like it very much. I have replaced/rebuilt the ABS pump, ECBM, the brake rotors twice in 89,000 miles and they need replacing again, the dreaded drivetrain clunk was an easy fix for me but others can't get rid of it. That's just the big stuff...and I still like the truck and will buy another Chevy...I really-really like the looks of the GMC Sierras but around here there are never any for sale.
One last thing...if you plan on upgrading the engine with a intake and maybe a programmer and exhaust...get a truck with at least a 5.7/5.3 engine...you'll be glad you did. Last edited by Sonny01; 09-29-2006 at 03:39 PM. |
They are generally good trucks though the 1999-2006 versions are greatly improved over the 1988-98 C/K line. I personally would look at a 5.7L (350) over the V6 for the added power and torque, but it depends on your needs.
The brakes on these trucks are hit or miss, I had constant problems with the drums on my 1998 Chevrolet, but others have reported no issues. The intake manifold gasket on the 350 is prone to leaking, and since the V6 is a 350 less two cylinders, that may be a problem there as well. I don't know. Windshield wiper motor circuit board is likely to fail but it it's a cheap and easy fix. Other than the usual accessory troubles (alternator, etc.) these are pretty reliable vehicles. Above all, have a good mechanic spend an hour or two looking over it for problems. It's well worth the $100-$200 before you buy. In 2000, I purchased a 1998 C1500 with 37000 miles on it from a local Chevy dealer. By the end of the year I had spent nearly $2000 in repairs and I wish I had had a mechanic look it over first. He would have spotted most of the problems. Good luck and hope this helps. |
I have a 91 2500 GMC truck w/a 5.7, but also a 98 astro w/a 4.3 my wife drives and I must admitt the astro the 4.3 vortec really does well, lots of torque even stock, after a tuneup the other day I played around and punched it and layed 30 foot af rubber, and these vans are heavy.
If your not going to be towing or hauling heavy loads all over the 4.3 might be ok. The truck has some drawbacks but being the 8600 gvw it will haul any load anywhere I want it to, it just depends on your needs. I agree with sonny01 in that this board has saved me thousands, though I'm not to bad on my own sharing little hints and tricks helps alot. |
I have a 98 sierra ext cab 5.7L V8 and I just love it. It had 175K km on it and its still running strong. The only major problem the 98's had were the fuel pump. They were loud (mine still is) and they burned up easily, but always having 1/4 tank of gas seems to keep it from doing that.
I have had a 98 with a 5.7 and loved it. Unfortunately it was totaled. Now have a 95 with a 5.0 and 5 speed. It is terrific. It gets 19 mpg and if i need to pull a small trailer it will do that as well. Only problem was the windsheild wiper board. Take care of it and that truck will last you a long time.
