Old 09-28-2006, 09:13 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
Ain't it Beautiful.
Just wanted to show my lastest acquisition. I plan to install it soon with a walboro 190 fuel pump at about 14-15 psi. Im curious to see how it feels compared to the tiny t-25. It is a 16g BTW but im sure most of you can recognize it. Anyway wish me luck with the install. Ive learned how to install by various forums and tech articles. Any (Dont do) advise would be appreciated however.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 09-28-2006, 09:14 PM
steviek's Avatar
steviek steviek is offline
Re: Ain't it Beautiful.
you will love it
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-28-2006, 09:15 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Niiice, I bet you felt like an 8 year old on Christmas opening that box up in the mail. I know I always do when an order comes in haha. Good luck with the install and let us know how it goes.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 09-28-2006, 11:24 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
LOL. T-25 to 14b was a big diffrence for me, and the 14b to evo316g was HUGE diffrence. I went 14.0 et on t-25 to 12.4 on my evo3 the same 20psi boost..
DSM geek
Old 09-28-2006, 11:30 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Speaking of Christmas Morning... looky looky what I got. Crower Stage 2 420a!
Not to hijack
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-28-2006, 11:46 PM
My advice is to install the oil feed line with alot of teflon, and don't over tighten it. You will crack the 2g filter housing. Replace the one turbo stud with a turbo bolt. Use Copper stick antiseze on the turbo/o2 bolts. If you can afford it, buy new turbo and o2 bolts. The stock o2 housing comes with one stud, some people take it out and use another o2 stud, but I kind of like it. It helps me line up the o2 gasket.
When you drain the coolant, TAKE THE RADIATOR out with the fans attached. All it consists of are 2 fan plugs, the upper and lower radiator hose clamps ane the 4, 14mm bracket bolts. You will really apreacate the extra room. Also when you unclamp the 2 tubro coolant lines, have a long hose handy that is snaked to a bucket. I forget the diameter, I think its the same size as the PCV nipple. ALOT of coolant poors out, almost a gallon...
Buy new copper crush washers for the coolant lines and oil feed, 2 per line, 6 in total. They are hard as hell to find, I had to buy them at the dealership. You will also want the 91 oil return line with 2 new drain gaskets. You can modify the stock 2g drain by filing the bolt holes closer, but it's a huge nightmare.. Spend the extra $32 and get the line and gaskets.
I've tried OEM, NAPA & Autozone turbo gasket kits. You can get a full gasket kit that has everything you need for about $36 including the oil drain gaskets, but the turbo and o2 gaskets are stock 6cm. With the 7cm evo3 I used the RRE $10 gasket kit.. Don't forget the Jpipe gasket while your at the dealership if you don't buy the full install kit....
When you install the turbo make sure you get the oil feed line attached to the turbo if you only have the 24" feed line, it doesn't give you a whole lot of room to play around with it. So just get it hand tight, then mount it up to the exhaust manny and tighten everyhing down.
DSM geek
Old 09-29-2006, 12:03 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
These pictures are nothing compared to my sweet pictures of when I got my parts.
Too bad they haven't made much progress from their boxes. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-29-2006, 08:47 AM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
He was probally sitting on the floor drooling lol I know I would have been.
Old 09-29-2006, 06:45 PM
Thanks for the info. As for everyone else, yes i was drooling for about 10-15 minutes. i think next weekend will be the date.
