Old 09-28-2006, 06:19 PM
mcbeefer mcbeefer is offline
tranny questions
im trying to find as much info on swapping a th350 to a th700R. i want to do this on my 79 in the future. Just wondering if any one had any good links on the specs of these transmissions as far as the lengths, bolt patterns, crossmember mounts, or any thing else related to the swap.
Old 09-28-2006, 08:46 PM
bag91's Avatar
bag91 bag91 is offline
Re: tranny questions
Summit Racing equipment has a kit just for that.....I dont know the link but go on the web site and see if you can find it.....
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 09-29-2006, 01:47 AM
Morley Morley is offline
As far as bolt patterns, it should bolt right up to any Chevy V8. Be aware you are going to need a different length drive shaft (shorter I think). If it needs to be shortened, just about any trans shop should be able to do that for you.
Old 09-29-2006, 07:48 AM
I knew about the shorter drive shaft could be up to 3 in shorter as well as possibly moving the crossmember. The other thing is I have the olds 403 which has the BOP bolt pattern (found some adapters to fit the two together on summit thanks). Guess i should have said its a 79 firebird.
