choking on gas fumes
when i drive my 64 catalina the exhaust fumes are really strong inside the car, i checked my exhaust and i dont have any leaks, and the fumes have never been that strong until recently, anybody have any advice?
Re: choking on gas fumes
Could be running too rich # 1, what changed that generated this problem though, floors all good, no change in exhaust design?
So this started afetr the exhaust work, if so start looking closely at connections. If the carb is loading up ( to rich) the engine would stumble or falter at idle normally.
Check in the engine compartment are you getting anyblow back around the valve covers plugged vent lines and ect. Look good in the engine compartment. Check for cracked exhaust manifolds. The v-8 had a valve which opened with a vacuum controlled valve on one exhaust manifold. Check that this valve is free and will open and the vacuum valve is working. I think they had a temp operated valve for this vacuum valve.
I am not entirely sure when they started using these valves. |
Check the fuel pump. On these engines the fuel pump will often fail and shoot gasoline out the side. The leak can start slow but will get worse and can cause other issues such as a fire. Also on check the oil for gasoline. Sometimes the fuel pump will shoot gasoline into the oil and will ruin the bearings.
