Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-28-2006, 12:44 PM
ghost1977 ghost1977 is offline
89 gm when i change cap and rotor core pack and started it up
And When I Started It Up The Fanbroke Off The Water Pump And Shot Off And Cut The Raditor And Now I'm Trying To Change The Water Pump Can Any Body Give Me A Easy Way Of Doing This Thank
I Have 89 Gm And 93gm
Old 11-12-2006, 08:29 PM
rhandwor rhandwor is offline
Re: 89 gm when i change cap and rotor core pack and started it up
You just have to start drain fluid.
Remove fan shroud
Remove hoses
Remove radiator trans cooling lines you need a disconnect tool.
Remove radiator
Remove belts
Watch and remove any thing in the way.
Then remove pump
Buy a haynes manual and check pictures
Use an air ratchet it really cuts down on time.
