Old 09-28-2006, 11:42 AM
denisew's Avatar
denisew denisew is offline
MAP sensor-high #'s
What in the world would cause a reading of 9.7 on the MAP, when the truck is sitting at idle, warmed up? I was able to check with a scanner. I have no codes coming up, but the truck just idles horribly. The longer it runs, the worse it gets. After long rides, it seems like it almost wants to stall, but hasn't yet.
What's been done?
plugs&wires-ACDelco
cap&rotor
air filter
fuel filter
fuel pump
cleaned MAF
new MAP last year-(threw the code for it)
tranny rebuilt last year
double checked new cap& rotor,air filter,MAF
Still can't figure out what I'm missing.
complete readings from scanner are at old post:
Actron Live Data-translation?
http://www.automotiveforums.com/vbul...d.php?t=585965
98 Blazer LS-2WD
4.3 vortec-W vin
Old 09-30-2006, 12:49 PM
denisew's Avatar
Re: MAP sensor-high #'s
hello......anyone? I just replaced this sensor about a year ago.
98 Blazer LS-2WD
4.3 vortec-W vin
Old 09-30-2006, 03:06 PM
Blue Bowtie's Avatar
Registered Offender
9.7 what? PSIA? Inches Hg? Volts? Depending upon your scanning software, the display may be different.
If it idles at 9.7 PSIA, that would be about 10.2" Hg vacuum, which would be a little low. If it's idling at 9.7" Hg, that would be even worse. However, if it's idling at -9.7 PSIG, that would be 19" Hg, which would be perfect. Which is it?
Old 09-30-2006, 06:02 PM
534BC 534BC is offline
poor mixture (either way), retarded timing, bad cam, valves, air leak, low compression, all can cause low actual readings.
A questions, what is the reading when decelerating, cold idle, and when held in neutral at 3000-4000 rpm?
Old 10-05-2006, 09:17 AM
denisew's Avatar
It's 9.7 HG. the complete list of details is in the link of my first post.
98 Blazer LS-2WD
4.3 vortec-W vin
Old 10-05-2006, 04:29 PM
denisew's Avatar
at cold idle, still 9.7, holding at between 3000-4000 rpm's it goes to 8.6, on deceleration it drops to 4.6 and back to 9.7
98 Blazer LS-2WD
4.3 vortec-W vin
Old 10-05-2006, 05:56 PM
Those sound pretty normal to me. Here are mine.
29.8 WOT
10.9 idle
8.6 3200rpm
4 decel
Old 10-06-2006, 08:58 AM
denisew's Avatar
Blue Bowtie stated that at 9.7 Hg, it is NOT good. I'm waiting to for a reply on why that is....
98 Blazer LS-2WD
4.3 vortec-W vin
Old 10-06-2006, 11:05 AM
denisew's Avatar
I did a vacuum test and it shows in the "normal" range, with no flucuations. Any suggestions are very appreciated.
98 Blazer LS-2WD
4.3 vortec-W vin
Old 10-06-2006, 11:12 AM
denisew's Avatar
Also checked PCV, it's good..this beast just idles horribly, sounds like it's gonna stall anytime it's at a stoplight. The longer it's running, the worse it gets. Somebody? ANYBODY?
98 Blazer LS-2WD
4.3 vortec-W vin
I seem to get mixed up when converting from traditional vac readings to MAP, but your reading of 9.7 is "better" than mine at 10.9 and I agree with your vac gage as it sure looks normal to me.
Have you checked the egr valve and checked for vaccumm leaks ?
Old 10-06-2006, 11:26 AM
denisew's Avatar
I'm using an Actron scanner, the one with the live data option. I honestly have no idea what any of the numbers mean. We just bought to check for codes.No, I haven't checked the EGR yet. Actually, I worried about busting the thing. I'm going off the Chilton's manual, and it says take it to the dealer. Says nothing on how exactly to clean it. It's a 98. I checked the vacuum off the intake. Where else should I be checking it?
98 Blazer LS-2WD
4.3 vortec-W vin
