Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 09-28-2006, 10:47 AM
Dian1 Dian1 is offline
Engine Oil all over spark plugs
I just took out one of the spark plugs of my Neon and it had oil all over it. It was soaked... Do you guys think that this could have caused the problem I was previously talking about - the car choking every time I press the gas pedal? It runs fine if I am extremely gentle on the gas pedal, but as soon as I push it just a little more (trying to speed up) - it starts choking and makes a banging noise coming from the engine...
Also, should I just replace the valve cover gasket? Is that the solution to the oil in spark plugs problem?
Thank you for all the help so far. Hopefully this will take care of my bigger problem...
Old 09-28-2006, 11:43 AM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: Engine Oil all over spark plugs
Have you checked the PCV?
If the valve is allowing oil to blow by, that could be where the oil is coming from.
There will be a path of oil in the air breather if this is the case. Cheap fix.
Old 09-28-2006, 11:49 AM
What is the PCV? Sorry, I don't have much experience... So I am not exactly sure what I need to do.
Old 09-28-2006, 12:37 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Your spark plug tube seals need to be changed. To get to them, you need to pull the valve cover, so replace that as well. A kit should run you about $20-$30.
Pressure Crankcase Ventilation valve. It's about a $5 part.
2003 Dodge SRT-4
Old 09-29-2006, 12:49 PM
Thank you very much for the tip. This is the first time I am venturing to do this, so I am a colmplete rookie... I got the whole kit with the valve cover gasket and 4 rings, which I am guessing are the plug tube seals... I took the valve cover out and now I am looking and trying to figure out where the little rings go - do they go in the holes on the cover? Also, do I need to do something to clean up the oil that was in the plugs so that the new spark plugs won't get soaked in or do I just try to reach in the plug tubes and wipe out as much as I can? Thank you.
Old 09-29-2006, 12:53 PM
The plug seals attach to the underside of the valve cover. Try to stick a shop towel down there to get the oil out of the spark plug hole.
2003 Dodge SRT-4
Old 09-29-2006, 01:56 PM
neon_rt's Avatar
Oil on the outside of the plug, not the inside, lol. Sorry.
Old 10-04-2006, 09:42 PM
Thank you very much. I changed the gasket and the rings and also found out that the cables were bad. The car is running fine now (well, there are still a few things to fix, but nothing as major). Thank you.
Old 10-04-2006, 09:45 PM
Thanks everyone. The car is finally running. Thanks for everybody's help.
Hey hey...good to hear! It's funny/irritating when you start to work on one thing and find other problems while you're at it.
2003 Dodge SRT-4
