Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-28-2006, 10:36 AM
Isuzu10 Isuzu10 is offline
99 Rodeo ABS
The ABS light comes on while normal driving on my 99 Isuzu Rodeo. It will "reset" following instructions in the user manual, but then comes on again. The questions are: What causes this? How much does it cost to fix? And is it something that an average do-it-yourselfer can fix? I've also experienced the typical joys of owning this type vehicle: rebuilt engine, new fuel pump/sending unit, etc.. Any help would be much appriciated.
Old 09-28-2006, 12:04 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 Rodeo ABS
You need to take it to a shop and have the codes read to find out why the light is turning on.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-28-2006, 12:55 PM
surferfletch surferfletch is offline
Re: 99 Rodeo ABS
Lots of ABS posts lately...
Old 09-28-2006, 03:11 PM
Isuzu Guy
Re: 99 Rodeo ABS
yup odd ..... If mine goes I'm just pulling the fuse and pretending like it is 1982 .....
-Ryan
Isuzu Moderator
Car Show Tips
Old 09-28-2006, 05:35 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: 99 Rodeo ABS
Check the wiring where it goes up the upper link to the frame. See if any of the wires at the plug there are broken. Look carefully because sometimes its hard to tell.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 09-28-2006, 08:16 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: 99 Rodeo ABS
BROKEN WIRES ON THE 98 AND 99 MODELS WERE COMMON
there may be a recall on the abs module I can check for you if you e-mail me the last 9 digits of your vin #
Old 10-03-2006, 06:06 AM
Letsrodeo's Avatar
Letsrodeo Letsrodeo is offline
Re: 99 Rodeo ABS
FYI
Here's a procedure to determine what ABS DTC (diagnostic trouble code) is active. It is done with out the scan tool by activating the ABS warning light flash code.
http://www.4x4wire.com/forums/showfl...ev=#Post632349
If you want something done right do it yourself two or three times!
1999 Isuzu Rodeo LS 4X4
American Eagle Series 149, 16X8
Toyo Open Country LT265/75R16
Rancho 9000
3" CP Lift, 3" PA Body Lift
Manual Locking Hubs, SuperWinch
Optima Yellow Top Battery
Custom Sound System
Shrockworks Rocksliders
Letsrodeo
