Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-27-2006, 11:05 PM
jhiler jhiler is offline
Won't start, will run
88 K2500 extcab with 350cid, manual tranny 4x4. Truck will run, albiet a bit rough if primed with a little gas in the TBI. But it does not start. Recent tank drop to fix broken ground wire. Pump runs when key turned on, gas is getting to TBI, but no squirt when cranking. Have not put a pressure gauge on it.
Jim Hiler
Albany, Oregon
http://home.comcast.net/~jhiler4/
Old 09-28-2006, 10:20 AM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Won't start, will run
Should be around 13psi on a tbi motor. The injectors are told to fire buy the pickup coil and the ignition module. Get a noid light to test for signal at the injector.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
