Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-27-2006, 10:24 PM   #1
Tommy in Brooklyn
Smile Woohoo I fixed the radiator!!
Thank to the encouragement and advice from the good Neon fans on this board, I made the attempt and was successful! It took about 90 minutes from start to finish. The only problem was that I didn't fill the system with enough coolant, initially about two quarts. Then I started her up and she promtly overheated. I pulled the radiator cap and poured in another gallon and there was no problem.
Thanks everybody,
Tommy
Now all I need to do is the clutch, the rack and pinion, the body work, and the paint and she'll be just like the day we brought her home in '95!
Tommy in Brooklyn is offline   Reply With Quote
Old 09-28-2006, 09:30 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Woohoo I fixed the radiator!!
Atta boy...told you, you could do it! Good luck with the rest of it.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
