Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-27-2006, 08:45 PM
r/t brian r/t brian is offline
Battery light on dash!!!!
I cant figure this out, just got done with a rear main seal on the neon and now my battery light stays on all the time, i check all the sensors that i removed and reinstalled, and also checked the bolts and gound wires that i took off and those are on good. Hooked up the auto scanner and it just says "low battery voltage replace if needed" WTF?!?! The battery is only 6 months old and i popped off the caps for the acid and those are full?
Any ideas??
Brian
Old 09-28-2006, 12:40 AM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
Re: Battery light on dash!!!!
check connections at alternator you may have and all grounds to make sure there clean you might have disturbed them.
Old 09-28-2006, 08:32 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Have the battery checked. Even though it's only 6 months old, doesn't mean it can't be bad.
2003 Dodge SRT-4
