Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 09-27-2006, 07:41 PM
philipk65 philipk65 is offline
'95 OLDS 88 engine problems!
I hope someone can help me! I have a '95 Old 88 with the 3800 series engine. When you first start the car and try the rev it up it wants to hesitate. but in 30 seconds it revs up fine. Also if you let the car sit 30-45 minutes after driving it and go to start it, it will start but it acts like it is flooded and shakes real bad for about 10 seconds. The check engine light comes on and off every few days. I've had the codes read but that turns up nothing! I've change plugs, it just had a new $600 computer put in, new air and fuel filters, a new PCV valve. Does anyone have any idea what this is? Or give me some info to go on? Any help would be greatly appreciated! Thanks. Kevin
Old 09-27-2006, 09:03 PM
Mickey#1 Mickey#1 is offline
Re: '95 OLDS 88 engine problems!
Could be a bad fuel pressure regulator. See if there is gasoline in the vacuum line going to the regulator. If so replace it - let us know.
Old 09-27-2006, 10:38 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
$600 on an ECM??? You. Got. Ripped. Off.
Check the fuel pressure, it should be around 40PSI. After that, you ought to clean the TB, MAF, and IAC. http://www.lesabret.com/phpBB/viewtopic.php?t=4054
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 09-29-2006, 05:43 PM
auto trainy auto trainy is offline
One quick question,have you been loosing coolant lately?
Old 09-29-2006, 08:18 PM
No, I'm not losing any coolant. And there is not gas in the fuel pressure regulator vacuum line. Kevin
Old 10-05-2006, 07:19 AM
Jdeck Jdeck is offline
Have you found the problem?
Old 10-05-2006, 04:38 PM
No, I haven't found the problem. I cleaned the MAF and IAC sensors and the intake where the butterflies are, like the link showed in detail, but still the car has no get up and go! What else should I look for or try. Thanks Kevin
Old 10-06-2006, 07:49 AM
Since I'm no specialist I can only grasp at straws. If it were supercharged I'd say the supercharger belt is slipping. This happened to me. I'm not sure if a clogged cat could cause this but it may be worth checking. Also, start it up at night when it's real dark and see if there is arcing from the plug wires. If not spray water on them and see if they arc.
That's all I have for you.
Old 10-06-2006, 11:44 AM
Thanks guys for the great info so far! How is an easy way is check a cat. converter? Thanks again! Kevin
