Old 09-27-2006, 06:56 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Annoying Engine Code..
Hey guys, i have an annoying prob, my check engine light comes on once and awhile, and if im lucky and dont have to unplug the batt, it goes away.. Its very weird, it comes on and off, like its been off for 4 days, then its on now, and goes off, and next day its back. One thing ive noticed when the engine light comes on is the Rad fan runs 24/7. Is this just showing that the electrical has a prob? Or is it probably the rad fan thats the prob? I have to pull the fuse so it doesent run 24/7, it makes it run worse and hogs more fuel.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 09-27-2006, 08:39 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
Re: Annoying Engine Code..
go get your code read
Old 09-27-2006, 09:39 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if your car is running worse and getting worse milage, theres more to this problem then just the radiator fan running constantly, just get the codes read, most auto parts stores do it for free
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 09-27-2006, 09:59 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
the fan is most likely runing because the computer has gone into fail safe mode(or limp home mode) meaning the computer knows there is a problem and it doesn't know how to solve it, so until a technicion fixes the problem, the computer will do what ever it can do to prevent the problem from getting worse, for example if the computer doesn't know what tempature the engine is, it will turn on the fan because it is safer to have a cool engine then to be overheating.(there are other reasons failsafe mode would turn on the fan.)
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 09-28-2006, 12:33 AM
Hmm, some good things to think about, thnx guys. I will see what happens then go and get it scanned. What shops are u guys talking about where u can get it done for free? Tirecraft etc charges like 70 bucks. U talking like partsource or napa or something?
Old 09-28-2006, 01:18 AM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Are there Autozones in Canada? They do it for free. A regular walk in mechanic shop might do it for free, just gotta ask around.
Old 09-28-2006, 08:29 AM
Autozone? I dont think so, i know part source, napa, etc. Ill ask around tho, thnx guys. I might as well get it scanned, cuz the abs lights on and has been for months anyways..
Old 10-08-2006, 08:39 AM
wannablast wannablast is offline
Sears sells the scanners for about $100. You will have to use a scanner to remove the codes. Unhooking the battery won't remove codes.
Old 10-08-2006, 12:34 PM
Blue Bowtie's Avatar
Registered Offender
Check Canadian Tire.
Old 10-31-2006, 05:00 AM
Bo-Tie Bo-Tie is offline
I have same prob ...check engine light on and off... borrowed code reader ...showed PO174 system too lean(bank 2) now does anyone know where i should look 2 fix this
