Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-27-2006, 06:08 PM
90laser1.8 90laser1.8 is offline
Oil pressure problems
Hello... I have as far as i know a stock 1990 plymouth laser 1.8.. and for some reason when i start it up from cold it has great oil pressure... but as the car warms up the oil pressure drops... when its running 3 grand the oil pressure is just clearing the bottum line on the gauge... it is a factory gauge... i can't figure it out... if anyone can help me please do... thank you
Old 09-27-2006, 07:22 PM
Killa's Avatar
Killa Killa is offline
Re: Oil pressure problems
Check the sensor, it might be bad.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 09-27-2006, 07:44 PM
ok... i shoulda mentioned this earlier... i'm mechanically inclined... so if u could also explain how to do it that would be great also... i'm new to this type of vehicle... use to driving a 84 montecarlo.... thanx again...
Old 09-28-2006, 12:24 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
The oil pressure sending unit screws into the bottom of the oil filter housing. Those sending units are the sensors and they do go bad quite often. Also the other problem is that the wire clips are sometimes loose on them and can come unplugged with natural ease. Of course your problem sounds to be a possible bad sending unit.
First I would start the car and let it idle until its to operating temperature and check the gauge. If your oil pressure is lower than it should be at that time then pull the oil fill cap and see if its slinging enough oil up around on the cams and such. If it has plenty of oil slinging around in there and the gauge reads that its too low then that tells us the sending unit is in fact going bad. If there is not enough oil being slung around then that means there is a larger possible problem. (oil pump going bad, oil filter clogged, oil pickup clogged, etc.)
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-28-2006, 08:31 AM
ok... i went out last night after i posted my ?... and it was of course dark... but what i could see with my flashlight is that there is oil going over the cam and everything.. and when i hit the throttle the oil sprays out the hole where the lid is... i'm just wondering if thats good oil pressure or if it should come out the hole idleing... thank you for ur help... and please keep sending more...
Old 09-28-2006, 09:11 AM
During idle it shouldn't spray out of the fill hole, but since it did when you revved it that indicates that it has plenty of oil pressure. I would say the next step is to replace your sending unit.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-28-2006, 03:46 PM
ok... today i went out and bought a sending unit... and i got a new oil filter and changed the oil... the oil pressure is doing fine... but it will be even better when i put the lucas in it... that has to wait till tomorrow... thank you guys for all ur help.... i'll keep u posted.
Old 09-28-2006, 04:27 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
... lucas... i wouldnt if i where you...
Old 09-28-2006, 05:18 PM
o... ok... what would u suggest using to make the oil thicker... that what everyone around here uses.. thats y i was going to.
Old 09-28-2006, 05:28 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
lucas..that was probably your problem in the first place.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 09-28-2006, 09:53 PM
no... the oil was thinner than water... lol.. that was the prob... and the sending unit was real rusty.. i took it off and it fell apart...
Old 09-28-2006, 10:57 PM
Yup, I'm totally the oil expert now. lol
I suggest running Amsoil with a stock Mitsubishi oil filter. Perfect combination there.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-28-2006, 11:36 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
I have a 94 Talon 1.8 and it runs good when started up and while im driving. While sitting at idle the oil pressure drops almost all the way down on the stock oil press gauge. So im always revvin up at the light which makes people think i wanna race. But it smokes so i put in castrol 10w30 high mileage and a bottle of that no smoke but i use a fram filter which i think might be a problem as i read some of the other threads about fram, i now switched to mobile 1 filters.
Old 10-01-2006, 06:59 AM
ya my oil pressure drops while idleing... the reason it smokes is because ur valve seals are out of it.. mine does the same thing... and as soon as u start driving the smoke stops? i used valvoline oil... with an stp oil filter.... everything is going great
