Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-27-2006, 03:36 PM
Tonglebeak Tonglebeak is offline
relieving fuel pressure
I'm about to change my fuel filter (so chances are I'll blow the car up and not be on these forums anymore >_>), and in the service manual it says to disconnect the fuel tank harness connector. Yet it doesn't seem to display in any of the diagrams of where it is.
I know where the filter is, I just don't know what the harness connector for the fuel tank (or did they really mean pump?) is, can anyone give a quick description on it?
Thanks.
Old 09-27-2006, 03:52 PM
caddyman379 caddyman379 is offline
Re: relieving fuel pressure
Is it a Ciera? Supreme?
if it's the ciera, go from the center of the tank torwards the engine and you should see it. it's probably blackened from age by now, but it unclips. disconnect it and run the engine until it stalls.
Old 09-27-2006, 04:03 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: relieving fuel pressure
That will work, you could also pull the fuel pump fuse, after the car is running to relieve pressure.
Old 09-27-2006, 04:18 PM
Yeah, sorry :S
1988 Cutlass Ciera 2.8v6
Old 09-27-2006, 07:01 PM
Alright, finally got the damn thing disconnected. I just want to be sure of two things before I continue
1) The service manual says that the engine will run until the remaining fuel in the lines is gone. My engine never did start, it cranked with the starter but never came on. Is that normal?'
2) It says to reconnect the harness after the fuel lines are empty. Wouldn't it be safer to leave it disconnected?
Thank.s
Old 09-28-2006, 03:07 PM
A990 racer
That is a reminder only, when you are done reconnect it.
