Old 09-27-2006, 10:14 AM
testtube's Avatar
testtube testtube is offline
removing egr on lt1
need to know what all needs to be removed for an egr delete.
Old 09-27-2006, 12:58 PM
poormillionaire2 poormillionaire2 is offline
Re: removing egr on lt1
All you need to know is here:
http://www.automotiveforums.com/vbul...d.php?t=616662
I'll be doing this too in a few weeks.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 09-28-2006, 09:51 AM
testtube's Avatar
what about the air pump under the ignition coil? should that come off too? And will I get any trouble codes from the egr actuator being unplugged?
Old 09-28-2006, 12:16 PM
Yes, I think you will throw codes for an EGR delete.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 09-28-2006, 12:37 PM
testtube's Avatar
any way to avoid the codes?
Old 09-28-2006, 01:29 PM
Zap em with a tune afterwards or don't remove the EGR components.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 09-28-2006, 04:50 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
OBD1 will not set a code if you remove the air pump but leave a fuse in the box for it and just have the wire hanging. Although when removing the air pump you are better off removing all that tubing and the bracket and the pump itself then plugging those fitting in the exhaust manifolds. Removing all these things really free's up usuable space.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-28-2006, 05:11 PM
Can you remove the EGR stuff but leave the AIR stuff, or do you have to remove the AIR with the EGR?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 09-28-2006, 05:14 PM
FormulaLT1's Avatar
Fight the powwa!!!
Yes. but I recommend removing them together and then paying the 50 - 75 bucks and getting them tuned out. For performance applications at least I think this is the better option.
Old 09-28-2006, 06:15 PM
Well, I just want to remove the EGR to get rid of the exhaust leak, not necessarily for performance gains. And I wasn't planning on messing with the AIR crap.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 09-28-2006, 09:28 PM
testtube's Avatar
I absolutely agree on the usable space thing. Im pulling my heads and really wish I had more room to work. Thats the main reason im doing the delete. Just to free up some room while im at it and less stuff to mess with when I put it all back together.
BTW...how good is the performance gain form the EGR delete?
Old 09-28-2006, 09:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
Don't delete the EGR if you are only doing so for expected gain cause you will be lucky to even see 1 - 2 horsepower from the microscopic amount of temp racing exhaust gas cycled into the intake manifold. The major advantage to doing away with the EGR is if leaks and fails. The most likely vacuum leak area on a stock LT1 intake manifold is at the EGR gaskets.
Plus you really don't need it, the LT4 did away with the EGR. Infact GM makes the block off plates for LT1's intake manifolds but not the passenger exhaust manifold.
