fuel lines
Okay, on my Z28 there are 2 hard fuel lines that run on the passenger side of the engine. They turn into rubber hoses and go to the fuel pump. One is a 3/8" line and the other is a 1/4" . Which one is Tank to pump, the bigger or smaller? And how would you tell?
John
1984 Camaro 5.7L 350 700R4 Holley 650 Cfm Edelbrock Performer Intake-Manifold Crane Cams Duration @ .050": 204/214 Lift:420/442 Summit HEI Distributor Hedman Shorty Headers Hedman Y-pipe Dynomax Turbo cat-back NOS Decal VTEC Decal |
Re: fuel lines
It's the 3/8 and should be able to tell as it's the same size all they to the carb.
Re: fuel lines
i am pretty sure one is a return and one is feed. so whatever one goes through the fuel filter is feed
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
Re: fuel lines
the line from the pump to the carb has been changed and a hose put in place of the hard line. and also the fuel filter is supposed to be just inside the inlet on the carb....
i know one is a feed and the other is return..and it makes sense the big one is the feed..i took a guess and put a universal fuel filter on the 3/8 line
Re: fuel lines
You could, and should put the inline filter in the hose from the pump to carb.
Re: fuel lines
i wanted to but...no room..
Re: fuel lines
Do you still have a filter in the carb inlet? Cause when the pump diaphragm starts to break down, guess where it's going to go?
