Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 09-26-2006, 07:35 PM
mitademedio mitademedio is offline
383 Heads
Will 383 Heads (60cc) Fit A Stock 350?
Old 09-26-2006, 07:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 383 Heads
There's no such thing as "383 heads", because the '383' is a bored and stroked 350. GM never made an SBC 383. 60cc? Do you have a part # for them? That's kinda small, and will require deep dish or reverse dome pistons in order for you to be able to run on 92 octane.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-26-2006, 08:00 PM
Re: 383 Heads
Thansk for the quieck reply,i found them in the add posted below
A set of 60cc GM heads (casting number 376450). They were working pulls off of a 383. They are fully assembled, and include rocker arms and pushrods. $75
I have an edelbrock performer RPM manifold that came in the natural finish but has been hand polished. Its dirty, but in excellent condition. $75
I have an edelbrock performer 600 CFM carb w/ manual choke. Ran great when it was pulled. $100
i did i search on the casting number and they came to be from a 305...dont know if thats true,i have a stock 350 with the four barrel holley carb,do u think it's worth to change the stock intake and the holley carb for those posted in the add?
Old 09-26-2006, 08:05 PM
silicon212's Avatar
Confoundingly Lucid
Re: 383 Heads
I was just going to say that those are 305 heads. I wouldn't put 'em on a 350 - just because they have small valves (305s came with either 1.72 or 1.84 intakes, with the 1.84 being predominant). If you want a decent set of 350 heads, do a search for 3991492 castings. They're 64cc closed-chamber with 157cc intake runners. Some came with 1.94 intakes, most came with 2.02s.
Old 09-26-2006, 08:08 PM
Re: 383 Heads
once again thanks,what do u think about the intake and carb,sounds like a good deal?
Old 09-26-2006, 08:16 PM
silicon212's Avatar
Confoundingly Lucid
Re: 383 Heads
Both of those should set you up. My engine used to be in another car, and when it was, it had an Edelbrock Performer intake with a Carter AFB 650 on it (the carb you have is based on the AFB), and it ran real good.
