Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 09-26-2006, 07:29 PM
redout redout is offline
1991 Water Pump
1991 Sunbird LE 3.1L, many many kilometers.
I'm currently experiencing a coolant leak. I'm unable to verify where it's coming from (hoses and rad) so my next guess is the water pump.
I understand that I should be able to see coolant leaking from the weeping hole but that's where the problem lies -- I can't be positive that the part I'm looking at is actually the water pump as I can't see any weeping holes.
Does anyone know of a weblink that shows my model car's engine compartment well marked, as I'm unable to find said picture, nor does my Hayne's Rapair Manual show a very good picture of it's location.
Thanks very much.
Old 09-27-2006, 02:38 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1991 Water Pump
The water pump is behind the top-most smooth pulley toward the front of the engine. If you remove the pulley (4 bolts) you should be able to see the weep hole in the casting.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
