ok im getting a 89 i rock with a tpi 350, it is tore down now and the new parts are a mild cam and flat top pistons , 64 cc heads (stock) i plan to put new valves in the heads with 1.6 rockers and heavyer springs
now i want to keep the FI what should i expect will it run ok and is the speed limmited by the computer and if so how can it be changed or would it be eazyer to put a carb on it
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit 93 accord 4 door auto stock |
Re: building a tpi 350
If there's a speed governor function, it's going to be at the rated speed of the factory supplied tires. Chances are that with that car, it will be high enough not to worry about. It too, can be reprogrammed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
A "mild" cam is what? How does it compare to the stock cam? Flat top pistons? What will the final compression ratio be? If the CR is kept to about 9.5:1 to 10:1 and the cam isn't much more than the stock cam (say like the corvette's cam of that year) then the stock injectors will work just fine and shouldn't need to be replaced UNLESS they are Multec injectors, those are/were junk and I'd replace them with some five-0 motorsport's 22# injectors. The ECM's PROM chip will need to be rewritten but the car should at least run enough to get the engine fired up and do the initial break-in of the new parts. You also ned to get a scanner of some kind, the best would be a laptop with a cable to connect it to your ALDL and software to do data logs of what the engine is doing. From this info you'd have a much better idea of what needs to be changed in the PROM programming.
Good news...the IROC's didn't have the speed limiter in their PROM set...well it is set...to 255mph (max setting) They were the top performers just after the Corvette, so they didn't de-ball them. |
great stuff guyz where do i go to get the computer re programed
how do iget such equipment
Good luck
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
Look here http://moates.net/ Craig has everything you'll need.
