Old 09-26-2006, 05:18 PM
79z28 79z28 is offline
'79 won't start....?
Hey everyone, I was wondering if anyone could help me. I came back from a business trip of 4 months and tried to start my '79 Z28. At the first turn of the key, it fired right up but struggled a little bit during idle. So I changed the oil and flushed the radiator fluid. Now it won't start. The battery charge is good because the starter cranks hard, strong, and constant and not sluggish, i took off the air filter so there will be definite air flow for combustion, i tried the starter fluid spray 3 times, and the fuel pump is good. I was thinking it would be the spark plug or ignition coil. If so, what's a good way to do an operational check. I also thought about the distributor. I was told that maybe the car is misfiring, if so, how do I adjust it? Any other problems you guys could think of or suggestions? Thanks!
Old 09-26-2006, 09:27 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: '79 won't start....?
while your trying to start it push the pedal to the floor and hold it for a little. and look to see if there is gas squirting into the carb when the pedal is pushed, you should see it squirt. its carb right??? if it is timing you loosen the bolt on the clamp down bracket on the manifold and spin the distributer- tiny turns make a big difference. if you turn it more then an 8th thats way far. you could try turning it a little each direction and trying to start it. might want to mark where the distributer initially was. remember just change it a tad, like an 1/8th an inch incriments
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 09-27-2006, 09:03 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Originally Posted by 79z28
i took off the air filter so there will be definite air flow for combustion, i tried the starter fluid spray 3 times, !
And the result was?
Old 09-27-2006, 06:47 PM
Originally Posted by wrightz28
And the result was?
the car still wouldn't start.
Old 09-28-2006, 08:59 AM
wrightz28's Avatar
Move on to the ignition system then.
Old 09-30-2006, 12:40 AM
Morley Morley is offline
Dead ignition module.
Old 09-30-2006, 01:08 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
^^^Ditto^^^
Also, check the pickup coil assembly. I've had these fail on me more than once, even on the tow truck I used to drive.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
