Old 09-26-2006, 04:46 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
two questions..
what is a stutterbox, and what does FTW mean?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 09-26-2006, 04:58 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: two questions..
the shutterbox is the thing on DSMlink where you can put an load on the engine at a certain RPM, to build up boost. (Launch) but FTW, i'm not sure... so i'll let someone else take that one.
Old 09-26-2006, 05:03 PM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Re: two questions..
A stutterbox helps you launch your car consistantly by keeping the revs at where you want. Correct me if I'm wrong.
FTW = For the win.
FTMFW
1992 Ẽfini RX-7 FD3S
Old 09-26-2006, 05:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: two questions..
Yes, FTW is "for the win" while FTL is "for the lose."
Stutterbox will not build boost, it allows you to floor the gas on the line and it keeps revs at a specific user defined RPM... like a rev limmiter.
Anti lag will build boost at the line. "The technique involves retarding ignition timing so far as to cause the exhaust valve to open well into the power cycle, resulting in extremely hot and explosive gases rushing past the turbine, spinning the turbo up like crazy." -DSMlink.com
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-26-2006, 05:25 PM
Re: two questions..
jesus after i read that i had to take a cold shower....seeeeexxxxxxyyyyy!!!!
eclipsed @ 3am
Old 09-26-2006, 05:40 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: two questions..
eek guys lots of wrong info in this thread
a stutterbox is essentially a calculated misfire at a preset RPM. It is not DSMLink specific and is used by many. This puts a load on the engine and allows turbos to spool at the line. The longer you let it stutter, the more boost it gets. The higher the rpm, the more boost. It works great for bigger turbos that don't spool very well initially, and it's fun as hell to tinker with.
Having the anti-lag option clicked in Link will make the effects stronger. However, a stutterbox by itself will still build boost off the line.
now - 2000 civic
soon - 2002 is300
Old 09-26-2006, 08:50 PM
Black99GST's Avatar
Re: two questions..
so... Thor, looks like i was right...
Old 09-26-2006, 10:13 PM
Thor06's Avatar
Jizzed In My Pants
Re: two questions..
Damn....
Guess I learned more than the first two laws of thermodynamics .
Old 09-26-2006, 10:41 PM
E-Klips E-Klips is offline
Banned
Re: two questions..
This is correct.
To add to the anti-lag, it retards ignition timing, set by you, creating a load on the motor and also adds a percentage of fuel also selected by you. Very helpful in spooling larger turbos while staging at the dragstrip.
To get an idea what helps/works... With the stutterbox alone I see maybe 3-5psi after a good 15 seconds @ WOT. With the stutterbox and anti-lag, I can get 15psi within 10 second @ WOT.
Old 09-27-2006, 09:08 AM
Thor06's Avatar
Jizzed In My Pants
Re: two questions..
So would it be good or bad to get to full spool on a smaller turbo car (say my b16g or future evo III 16g or 50 trim setups) at the line? Would it even be possible?
Old 09-27-2006, 09:27 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: two questions..
on my 14b my studder box would spool to about 5-6psi @ 5000rpm. With Antilag (probably the demise of my turbo) I saw 17psi off the line. my Evo316g studders at 10psi at 5000rpm. It only takes about 2 full seconds to build max boost on the studder..
DSM geek
