Crusie Control
Before mine went out, the cruise would automaticly start speeding up by itself. I was interested in fixing it but there isnt any aftermarket support (Carquest, Autozone, Advanced auto) Has no parts for the cruise.
Any Suggestions?? Its a 95 Neon SOHC Thanks Brian |
Re: Crusie Control
SPEED CONTROL ACCELERATES OR TAPS UP BY ITSELF:
Check for diagnostic trouble codes. If code 15 refer to the Powertrain Diagnostic Manual, if code 34 perform the following test: (1) Conduct the speed control switch test on the resume ACCEL/SWITCH. (2) If it failes, replace switch. (3) If it passes, disconnect the 4 way connector at servo. Test continuity of pin 1 to ground to test for intermittent short. Wiggle wires while preforming test. (4) If continuity to ground, repair wiring. (5) If no continuity to ground, replace PCM. Hope this helps you out.
2003 Dodge SRT-4 |
Re: Crusie Control
Thanks for the info das, ill check on it sometime next week because right now i got another issue with a low battery light......check out the thread.
Thanks Brian |
