Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 09-26-2006, 10:02 AM
smokin63 smokin63 is offline
oil pans
I am thinking of installing a high volume oil pump in my 63 that has a 350 in it but am not sure if what it would take to get the pan off ? can it be done without lifting the motor?
Old 09-27-2006, 03:20 AM
FinnBowtie FinnBowtie is offline
Re: oil pans
You need to remove the tie rod, atleast if you have a rear sump? I believe you have a rear sump-pan if the engine is 350.
Old 09-28-2006, 11:49 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: oil pans
The pan on the early Novas have a front sump. You'll have to lift it up fairly high to get the pan clear of the frame and oil pump.
Bob
Old 09-28-2006, 08:55 PM
rhandwor rhandwor is offline
Re: oil pans
You might have to mark your dist rotor and the side with whiteout and remove the dist to get the engine high enough. The will prevent breakage as you will have loosen the motor mounts and engine hoist or jack to raise it.
