Old 09-25-2006, 09:50 PM
1990eclipseGST 1990eclipseGST is offline
Angry Car took a SH*T
SO for a while now my syncros were going out and now my timing belt snapped and bent valves. Its been having probablems since i got it. So this gives me a good chance to go through the car i was woundering if anybody new good parts to you for it, its a 1990 eclpse gst (stock turbo) im trying to keep it under 4k for everything not including the paint rims ect. and suggestions Bodykits? performance? and info/suggestions/parts would help thanks alot
Old 09-25-2006, 09:54 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Car took a SH*T
Bodykit... NO!!
It all depends on what you want to do. Stock rebuild will be relatively cheap. If you rebuild everything, you can get over thousands and thousands of $$$. It's your choice on what you want.
USE THE SUB FORUMS!!!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-25-2006, 11:23 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Car took a SH*T
4k for a build.... where to start :devillol:...
I'd do a stock rebuild, have shep rebuild your tranny, get dsmlink, injectors, pump, FPR, exhaust, bigger turbo (I'd suggest a 50 trim), boost control, some guages, FMIC, cams, maybe an Evo III exhaust mani and o2 sensor housing, thats about it. You'll still have some left over if you search around a get good deals. Oh yeah dont forget the alcohol, you might need some of that .
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-26-2006, 12:18 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Car took a SH*T
A 6 bolt crankwalking....granted it's old, but still. Rarely heard of.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-26-2006, 01:34 AM
Re: Car took a SH*T
SO THE TIMING BELT BREAKING IS A CRANKWALK I WISH I WOULD HAVE KNOWN THAT IN THE FIRST PLACE THAT WAS WHAT WAS WRONG WITH THE CAR WHEN I GOT IT
Old 09-26-2006, 12:16 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: Car took a SH*T
Where did you come up with this from? He stated in his first post that his timing belt snapped therefore bending valves...crankwalk has nothing to do with HIS problem.....
Old 09-26-2006, 01:03 PM
sr20dk sr20dk is offline
Re: Car took a SH*T
don't know where crank walk came from, but not crank walk in a 6 bolt
Old 09-26-2006, 02:45 PM
Re: Car took a SH*T
I guess I misread it then. But isn't the belt breaking pretty much the same thing as the belt skipping? The outcome is the same. Maybe I need to read up a little more on crankwalk and what EXACTLY it is.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-26-2006, 04:29 PM
david-b's Avatar
Dave is THAT guy
Re: Car took a SH*T
Yeah. Skipping a tooth or break the belt is not even close to crank walking. When that happens, the head usually gets messed up. When it crank walks, the crank and block gets messed up.
75 Monte Carlo
