Old 09-25-2006, 09:24 PM
karson karson is offline
Question problem with breaks
I changed my front breaks on the passengers side, inner pads were worn down to the metal.
The outer pads were practically new.
Can anyone tell me what could cause one side to wear down and not the other?
Old 09-25-2006, 10:08 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: problem with breaks
I replied to your other post...why did you make two posts about the same problem?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 09-26-2006, 12:06 AM
canatto canatto is offline
Did you insepect and grease the two caliper guide bolts for an easy sliding over the mounting bracket? If the caliper was stuck or very hard to slide you'd get inner pad to wear a lot faster than the outer one.
Old 09-26-2006, 05:40 AM
Thank you. I will do that today
karson
