Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 09-25-2006, 09:05 PM
white97altimagxe white97altimagxe is offline
Send a message via MSN to white97altimagxe
Question Would this do anything?
http://www.eautoworks.com/html/ORD-1-1-1-23754.cfm
I am trying to find a cheap way to upgrade my head lights, I have limited funds and ran across this item.
I purchased a set of HALO xenon bulbs that where suposed to be 100/90 watts and they dont work right, but suposedly if I up grade the head light system they will put out 170/160 watts. The package states 4500k(so they should be better.
I dont know if this item(link would help) or if I should buy an HID system.
Old 09-26-2006, 05:11 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Re: Would this do anything?
you better check state laws on headlights and stuff cause alot of lights are way to damn bright and you will get pulled over for it. i had 100 watt bulbs for a while and i got busted for them now i got silverstars paid 40 buck but they are 50 state legal and just as bright
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 09-26-2006, 06:53 PM
I've checked, and i'm good up until 8500k.
Anything more and im pushing it. But my province has a law that states its ok up to 8500k.
The bulbs that i have in and the kit that the link is for would make the bulbs good for 4500k, well under the laws maxamuim.
