Old 09-25-2006, 05:55 PM
fastGTP01 fastGTP01 is offline
rpm shift?
well my reprogrammed pcm shifts at 6200-6300, is that too much? stock internals and stock tranny. thanks.
2001 Grand Prix GTP(daily driver)
-cold air intake
-slp headers
-u-bend delete
-reprogrammed pcm
-autolite 104's
-3.4 ZZP
1988 Chevrolet S10<--4-SALE PM me>
-H.O. 305
-crane cam(272 dur. .454 lift)
-570 street avenger
-th350 with shift kit and hurst floor shifter
-edelbrock performer rpm intake
-double roller timing chain
-hedman headers
-true dual 2.25" with dynomax mufflers
15.1 @ 98 mph <-- lol i need traction(factory one wheeler peeler)
Old 09-26-2006, 03:42 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: rpm shift?
Did you ever check to see who re-programmed your PCM? Was it DHP, Intense or did the prior owner use a PowerTuner?
The stock WOT, tranny in D shift points are set for 5800 rpms. PCMs programmed for Stage 1 mods are set to shift around 6000 rpms and that is with performance shift on.
So if you are shifting 6200-6300 it is high for a stock engine. My Intense PCM is programmed to shift at 6200 rpms and rpm cutout is 6500 but I customed programmed for 1.8 roller rockers and my other mods. Therefore you have some form of Stage 2 programming. Do you notice any valve float at those rpms?
Timeslip 08/12/06
AF Community Guidelines
Old 09-26-2006, 08:58 PM
Re: rpm shift?
it is a factory pcm reprogrammmed by powertuner.
no i did not notice any valve float at all, or any out of ordinary for that matter. it winds right up to 6200-6300 very quickly like it should shifts, and winds back into with no shifting problems or motor issues. im just wondering shoudl it couase any long term issues?
-cold air intake
-slp headers
-u-bend delete
-reprogrammed pcm
-autolite 104's
-3.4 ZZP
-H.O. 305
-570 street avenger
-hedman headers
Old 09-27-2006, 11:07 AM
BNaylor's Avatar
Re: rpm shift?
It probably won't hurt but I wouldn't make a habit of WOT/pedal to the metal. The SII 3800 valvetrain is fairly reliable and resilient.
BTW - But as a friendly reminder just remember what happened to your other engine.
Good luck.
Timeslip 08/12/06
Old 09-27-2006, 02:15 PM
MIKES3's Avatar
MIKES3 MIKES3 is offline
Re: rpm shift?
uuummmm. You better set your shift points back to stock. You dont have a CAM with 105lb springs or 1.8 ratio rockers or higher with 90lb springs. You not producing any power past 5400 RPMs. I would fix that ASAP otherwise you car will be hurting. I have 1.8 roller rockers and I have my 1-2 shift set to 6000 RPMs and the 2-3 shift set to 5800 RPMs. Unless you buy a VS or XP Cam you DO NOT want to set those shift points set that high. If you have the Power tuner there is a way to set your RPMs back to stock. I think you go to the RPM section and right click and set all back to stock / original.
2004 GTP
3.2 MPS, FWI 9 inch K&N, ZZP motor mounts mandrel bent 2.5 inch exhaust w/ flowmaster 40s, resonator delete, 3" DP w/o CAT, MSD coil packs Autolite 104s, Autometer Boost Gauge, DHP Power Tuner, S&S Ceramic Costed Headers, W-BDY Store STG III IC, Hawk PADS Power Slot Rotors, 1.8 Roller Rockers, 90lb Springs, LQ4 MAF
14.5 stock w/ 2.2 60'
