Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 09-25-2006, 04:25 PM
n8zdogg n8zdogg is offline
Best $ for wheelbearings
Since I've seen quite a few posts like mine about wheel bearings, who's got the best price?
Old 09-26-2006, 06:05 AM
jdq jdq is offline
Re: Best $ for wheelbearings
I found a parts place 105 bucks in hamilton, ontario only had 1 in stock.Dont know how good it is but my bonneville cheapest was 170
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 09-28-2006, 02:20 PM
steelerguy steelerguy is offline
jdq: Did you fix the roaring noise starting around 40mph with the front hub replacement? Was yours no ABS hubs (ABS in rear only)?
Old 09-28-2006, 06:13 PM
jdq jdq is offline
Funny u ask today I went to buy it and he asked me if I was ABS in front or not and I did not know , so would anyone know or how do I find out.2000 Durango 4x2 SLT. 5.2 L
Old 09-28-2006, 06:26 PM
If you call your VIN # into Dodge 800-992-1997 between 8-5 all time zones it says on dodge.com, they can tell you.
To update you on what I found out today, I stopped into a local pepboys that was slow & they said they could look at it right away. The mechanic & I took a short ride & it sounded to him like one or both hubs were making that bad noise.
But when we got back to the shop & put it on the lift, you could see that all 4 ball joints were shot, particularly the uppers & as well as the drivers side inner tie rod. He said that the left front tire had developed cupping (probably from the worn out suspension) & that was probably causing the noise. Cupping was just little bumps about 2 inches in from the inner edge that you can readily feel when you spin the tire. I guess they can form anywhere.
Anyway, I'm going to fix the suspension & take the bad tire back to try & get them to replace it under my road hazard warranty. Will dirty up the new parts with some grease or something.
Old 09-28-2006, 06:34 PM
jdq jdq is offline
Isnt upper ball joints on a recall, what yr is yours.Mine is definately driver side and 4 months ago I took it in for ball joints to check for recall and they said they were fine and fixed one tie rod.I hope it is bearing only I am trying to sell this.
Old 09-28-2006, 06:58 PM
I would take them to an independent mechanic to have them & the lowers checked again. I don't trust dealerships. If they can't generate cash, they don't try very hard.
Mine's a 1999 & the local dealership plus Dodge says no to my VIN #.
Also http://www.dodge.com/owners/index.html
Top, middle left you'll see recall notices. Click that & enter the last 8 #s of your VIN
Your complete VIN will print out & any known recalls.
Old 10-02-2006, 12:24 PM
Should have been more specific, I have the 2001 4x4 w/ 4 wheel ABS.
Old 10-05-2006, 10:23 AM
Here's what I found -- for the front hub with ABS sensor
NAPA - $207ea Autozone - $189ea Roadiron parts on Ebay $97ea (the shipping to me in Ohio was $20) , and he has a lot of other rotors, tie-rods, brakes etc for many different vehicles.
