Old 09-25-2006, 04:50 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
What a week so far...
So yeah.. last week, worst I've had in a while. Started off with me simply installing a new 180* stat. That's when it went downhill. 1st, my water pump started leaking. So, I decided to just go ahead and replace the whole thing. Cars at 120k miles, so why not? So I got the old one out and the new one in, worked like a charm. Then I had some hoses start leaking where the metal band goes on the end. So, took out the bands, replaced them, tightened everything down, viola.. no more leak. Well after all that was said and done, the car started misfiring, and bad. I couldn't understand it. So I swapped out the coil packs with my spares I had off my other engine I have, and bought some stock ACDelco spark plugs and stock replacement wires and went at it. Now, it runs... I'm just waiting for the next thing to break on me. And never again will I use those NGK Iridium spark plugs. I only had those in for 20k miles and yet one of the tips was completely erroded. Had nothing left on it. What's tripped me out the most about this, is the problems happened back to back. One after another. I'm just like wtf??
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-25-2006, 05:27 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: What a week so far...
you break a mirror or something
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 09-25-2006, 05:41 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
I feel your pain. When I got my car it was first a tranny leak, fixed it. Then exaust leak, fixed it. Then a rocker arm came loose, fixed it. Then my passenger side window motor crapped out, working on it. Then the hack job alarm that came with the car decided that I don't need a working ignition so since yesterday I've been starting my car by turning the key on, popping the hood, and jumping the starter silonode with a wrench. It should be fun fixing that one. It's was pretty much as soon I got finished with one thing another popped up, but on the bright side most of that stuff is going to hold up for a while, if not I'll just fix it again.
EDIT: Forgot about a broken shock mount and inaccurate tach, but I don't take corners too hard and I have an automatic so they're no biggie.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 09-25-2006, 06:01 PM
blindeyed's Avatar
eBay aDdict™
Damn, and here I thought I was having it bad. I don't I could have the patience to deal with that stuff.
On a side note.. has anyone ever lost their locking lug nut key? I need to change my brakes badly.. but can't seem to find the friggin thing.
- Jason
Old 09-25-2006, 06:52 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I have lost several of those. If it's the factory type (round with lines in it) find another key and beat it on with a hammer. They turn right off, then put the key in a vise and punch out the lug nut. If they are the thread on key type use a grinder to put a flat spot in it (if you can get at it) and turn it with a pipe wrench. If that won't work, you're gonna be drilling for a while.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 09-25-2006, 06:53 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Id head out to a rim shop, usually they'll sell you a lock for 10 dollars.. thats what I had to do because I lost the lugnut key for my Monte's rims.
Old 09-25-2006, 07:16 PM
Nate355RS's Avatar
Ah, it's not so bad, all that stuff happened over the course of about 3 weeks. I actually like it cause it helps me wind down after school and work and just take it easy fixing some stuff. And it's a really good feeling right after you fix something on your car that was not working before. The exaust leak was the hardest but it's sealed up good now, and I think I'm going to just pay someone to fix the window motor, don't think I have the right tools for that and I don't like puzzles where you can't see the pieces. Oh yea, a few beers always help with any frustrations.
Old 09-25-2006, 08:04 PM
blindeyed's Avatar
eBay aDdict™
Yeah my lugs came with the rims when I bought them on ebay. Not sure what kind of locking lugs they are, but they are identical to these:
http://www.westcoastcorvette.com/ima...ts/lugnuts.jpg
I'm guessing those are stock Corvette lockers?
Oh c'mon man, if you can do all that other stuff mentioned then you can surely swap out the window motor. All you really need is a drill and some basic tools. Took me about 45 minutes the first time I did it on mine. I'm sure Rally can give ya some good pointers with doing it on a third gen.
- Jason
Old 09-25-2006, 08:26 PM
Nate355RS's Avatar
Yea, I think you talked me into it. I was contemplating going ahead and doing it myself, I just need to get in there and figure out how it all works. If worst comes to worst and I can't quite finish it up, one of my family's life long friends owns a shop and he'll do it for next to nothing and show me how.
Old 10-15-2006, 09:09 PM
blindeyed's Avatar
eBay aDdict™
I spoke too soon... now the starter went out. I was pissed and was being sarcastic with my dad on saying that I should just trade it in for another car with lower miles. That's when he said by the time I'm done fixing all these problems I keep having, I'll practically have a brand new car. That helped alleviate the mood a little since it did make sense.
Any tips you guys can give on changing a starter? I'm pretty sure it's the same concept as changing one on a V8. I'm 99.99% sure its the problem, because when I went to start my car it did nothing. No sound at all, just nothing. So I got a hammer, banged it on the starter a few times, and it fired up np. Before that it did seem like it was having trouble starting a few times.
- Jason
Old 10-16-2006, 10:58 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
this is on your 3.4 'bird right?
If so, the crossover is a unrelentive poo head. My neighbor was trying to swap his kids starter, didn't feel like going out there 'cause it was cold. After seeing him out there for a few hours (and consumed a few brews) I figured I 'd better see what the hold up is before he dies of pneumonia.
Long story short, he was trying to drop the exhaust from the front, broke half the damn bolts. I've dealt with the same issue in the v8 3rd gens and knew better to pry the pipe down a little while another set of hands jambs the starter in place Just don't go too nuts on it
Old 10-17-2006, 10:19 AM
blindeyed's Avatar
eBay aDdict™
Yeah, it's my 3.4. In fact, I just finished doing it last night.. might I say, some absolute BS! I had to take off my entire passenger side header just to get the frigger out. Which, just to get that off, I had to take off my whole accessory bracket, my altenator, my compressor, and part of my coolant line (to get to a bolt holding the accessory plate on).
After getting all that crap off I got the old one out with no problem. I got the new one in, and went to tighten the positive terminal on it, and that pos screw coming out of it broke it half. I was barely even turning the wrench, and I felt no resistence so i just kept turning waiting for it to tighten up, then all of a sudden it just broke off. So I went back to Advance Discount, and of course they didnt have any more starters I could exchange it with, so i had to drive 10 more miles away to their larger store with the wharehouse, waited 30 minutes in line and finally got it. Went home, got it all put together, worked great.
Now, I just got home from school and my altenator feels like pissing me off. On the way home, it decided to stop working. My radio was flashing off and on, and I barely got up our driveway (tranny got stuck in 2nd gear, go figure, electronic). So now my battery is dead, and I cant get to work. I'm gonna wait for it to cool down and check to make sure I have the terminals tightend down on it first, which I'm pretty sure I do. Both the altenator and battery are about 2 years old, so I dont see either of them already going out on me. I swear, I'm getting to the point to where I'm about to just trade this damned thing in. If it's not one thing then it's another, and once I fix that damned thing I've got another to fix right after it. It's BS, I dont any kind of time interval between all this shit breaking down, it's all just back to back.
- Jason
Old 10-18-2006, 11:16 AM
wrightz28's Avatar
Meh screw all that removing junk, a little brute force with a pinch of I don't give a flyin rat, gits-'er done
