Old 09-25-2006, 09:59 AM
doeyh doeyh is offline
Engine rough after spark plug change
I installed new AC DELCO platinum last night.
Since then, my engine gets rough and hesitates in 1000 ~ 2000 rpm in acceleration. TT
Any advice will be appreciated.
Old 09-25-2006, 11:14 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Engine rough after spark plug change
Were the wires installed in the correct order? They may be firing wrong. Just a thought....
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-25-2006, 11:39 AM
muddog321 muddog321 is offline
AF -Advisor
Did you carefully twist the wire boots before pulling off - maybe you separated a wire internally - seen that one if it came off really hard or with a snap. You have to check the resistance of each wire to see. Is this all you did - as for the order the drivers side is 3-1-5 in the cap front to rear and its marked while pass side is 2-4-6.
Old 09-25-2006, 11:55 AM
I changed one by one. so, It is not possible that I plug in wrong spot.
My car is manual shift. when needle hits around 2000 rpm, it usually turn "shift" lamp on. so, I am using 1000 ~ 2000 rpm a lot.
When I drive in city road with around 40 ~ 50, rpm is usually under 2000.
The most used rpm rage is in trouble. It runs well over 2000 rpm.
Old 09-25-2006, 01:45 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Did you put the wires on the plugs one at a time?
Did you change the cap and rotor?
Did you make sure all plug wires were attached properly?
Did you gap the plugs properly?
What year is your truck?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2006, 08:56 PM
Yes, I put the wires on the plugs one at a time.
Cap & rotor?? you mean distributor??
I think all plug wires were attached properly. but wires are old ones.
I check all the gap with gap gage.
2001 model.
I pulled out each spark plug and ran the engine to see what happen.
I could see the difference each time I pulled out.
But, I am trying to replace the spot with old spark plug where least difference is happening. I will let you know soon.
Old 09-25-2006, 09:23 PM
BlazerLT's Avatar
AF -Advisor
There is a distributor cap and rotor you need to replace.
What gap did you set the plugs too?
What AC Delco plug number did you use?
Old 09-26-2006, 03:09 AM
534BC 534BC is offline
It can also be a cracked plug. The white stuff porcelain. Ceramic looking stuff.
Old 09-26-2006, 08:50 AM
billibong's Avatar
billibong billibong is offline
You stated that the plug wires were old. I think I would spend the cash to get a set of AC Delco plug wires and replace them. You may find a huge difference.
Also, you should get a new distributor cap and rotor. Make sure you buy a good quality cap - preferably AC Delco - as the after market caps have caused problems with several of the forum members vehicles. They tend to go bad quickly and you get multiple misfires due to small cracks in the cap.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 09-26-2006, 09:14 PM
Thank you for all advices.
Problem solved.
It was defective spark plug.
I took out one new spark plug and installed old spark plug and test-drove.
After several trials, My engine worked smoothly.
I exchanged that defective spark plug and my trucks runs well again.
If I would change spark plug again, I would change 3 plugs first and see how the car runs.
Thanks guys....
Old 09-26-2006, 09:30 PM
BlazerLT's Avatar
AF -Advisor
You better change you distributor cap and rotor or your truck won't be running smoothly for long.
They have to be changed every 2 years.
