Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-25-2006, 08:32 AM
CUBBY782005 CUBBY782005 is offline
Fuel Injector Help
Have A 1988 Buick Century Lost Fire Fixed That Now Injectors Wont Fire . Will Run If I Spray Starting Fluid In Intake Replaced All Relays And Ecm And Coilpacks Any Ideas How To Fix Prob Or What Prob Is Also Replaced Fuel Pump
Old 09-25-2006, 03:07 PM
maxwedge maxwedge is offline
A990 racer
Re: Fuel Injector Help
Welcome to AF, first, what engine?
Old 09-26-2006, 05:51 AM
It Is A 2.8 Liter Sorry Duh Important Info But Since The Post I Have Also Replaced The Crankshaft Sensor On Advice From Friend At Local Garage
Old 09-26-2006, 12:43 PM
jdl jdl is offline
When the engine is cranking, is there an injector pulse?
I believe under a certain rpm the ignition module controls the spark. It is possible for the ignition module to see a signal and the computer doesn't. If the computer doesn't see an rpm signal, the injectors won't pulse.
There should be a purple wire with a white tracer going from the ignition module to the computer, with the engine cranking, there should be a signal on that wire. No signal and the injectors won't pulse.
There should be an oil pressure switch in the fuel pump circuit. Even if the relay is faulty, once you crank it enough to build oil pressure, the pump should run. You should have fuel pressure?
Old 09-26-2006, 01:49 PM
HOW DO I TEST TO SEE IF PURPLE WIRE HAS SIGNAL?
Old 09-26-2006, 02:46 PM
jdl jdl is offline
If you have a DMM that has a tach--dwell or frequency setting, any of these will react to a dc pulse. I believe a digital logic probe will also react to a pulse.
If you have a scanner, you can crank the engine and look for the rpm readout.
If you wanted to test an injector, you could use a noid lite on the injector plug, crank the engine, the lite should flash, if the computer is pulsing the injector. Sometimes you can lay your finger on the injector, with the engine cranking, and feel a vibration. You might be able to hear it click or buzz.
Old 09-26-2006, 03:03 PM
A990 racer
Lightbulb Re: Fuel Injector Help
Make sure you check the pcm/injector fuses.
