Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 09-25-2006, 07:24 AM
msb1766 msb1766 is offline
2000 Cirrus Cruise Control Problem
When setting the cruise to a set speed with the set button the engine will surge a little bit more than normal.
Old 11-26-2006, 07:54 PM
martola martola is offline
Send a message via Yahoo to martola
Re: 2000 Cirrus Cruise Control Problem
Those earlier systems had a tendency to overshoot speed a bit,be careful to set the speed while keeping the throttlr depressed at the speed you are driving,& let the cruise solenoid take the throttle over,you'll feel it. Don't let go of the throttle until then 'cause then the cruise will over compensate for the speed you have lost between the time you pushed the button,& the time the throttle is pulled enough to make it back up.
