Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-24-2006, 10:00 PM
96eclipsegsx06 96eclipsegsx06 is offline
squealing noise
There is a high pitched squealing noise coming from the under the hood. i just replaced all three of the drive belts. the noise only happened once. any ideas of why it made that noise would be appreciated.
1996 Mitsubishi eclipse gsx
76500 miles
Old 09-25-2006, 01:25 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: squealing noise
belt is too loose....I would tighted it up if it continues...mine would do it until it warmed up a little bit...I went through like 3 belts in a month because I thought I had it tight enough but I was wrong....
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 09-25-2006, 09:46 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: squealing noise
If it only happened once, then it's no longer a problem...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
