engine wont start
I have a 1995 ford contour 4 cyl. I was driving down the road and the engine shut off (as if I had turned the ignition off). I tried to start it and it wont start now, it cranks but doesnt start. I checked the fuel pump and its working, I recently changed the gas filter so that cant be it. Any suggestions on some things I can check before taking it to a mechanic?
Re: engine wont start
timing belt?
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
Ill take a look, any other suggestions are welcome
check the timing belt first. also check all the pulleys on the serpentine belt and see if any are locked.
Im no mechanic, but is the timing belt suppose to turn when i crank the engine? if it is, it's not. And yes all the pulleys are rotating |
it isnt broken. I took the cover off of the timing belt and it actually did a full turn (slowly)then stopped again while the engine was still being cranked. When I stop cranking the engine, the engine sounds like some rocks in a tin can.
Thats An Interference Engine (if The Timing Belt Brakes Or The Teeth Rip Off The Valves Hit The Pistons)sorry About Your Luck
All zetecs are non-interference motors.
Dude I've Put Timing Belts On These Cars More Than Once Belive Me They Are.
IT'S A 16 VALVE DOHC WHATEVER IF YOU DONT LINE THE SHIT UP RIGHT YOU WILL BEND THE VALVES
Have you ever seen the internals of a zetec? Theres no possible way for the valves to come in contact with the pistons. Just because you've replaced them doesn't mean its not a non-interference motor. Do you own a contour? Have you ever had a zetec apart? If both awnsers are no quit arguing. I think I know my OWN car more then you do.
Yes I Have Replaced Heads On Contours Because The Valve Are Bent Does Yur Contour Have Variable Valve Timing?
VCT or not they are non-interference. The only way to make them interference its to run a HUGE cam..
