Old 09-24-2006, 05:28 PM
Skymarshall45's Avatar
Skymarshall45 Skymarshall45 is offline
new to the forums...need some advice
hello all. glad to be a part of the crx community. so heres my first question. i recently bought an 89 crx hf, and started on the body work and such..now that im finished with that i sourced a 91 integra with a b18a1. ive got swap mounts on the way, i was just wondering if there are any problems or things i should know before hand, i know that im gonna use the front and rear spindles and disk brakes from the integra, that way ill have disks all around and so the integra axles will fit. im a pretty confident mechanic and have performed the same swap in a 89 ef civic sedan and an 89 hatchback. just let me know if theres anything majorly different to perform this swap in a crx,( bending, bracing, etc) thanks in advance for all your help and pardon the crappy typing.
Old 09-24-2006, 05:53 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: new to the forums...need some advice
Its the same as it was on the civic, shouldnt have any problems.
Old 09-24-2006, 10:26 PM
Hybrid1990crx's Avatar
if you have done it before you wont have a problem. just make sure you bang the frame rail out for clearance of the alternator and the rear crossmember lip for the mount.
I recently swapped a b18 into a 91 si hatch and we had problems with the crankpulley not clearing the frame rail, we thought it might have had something to do with the car being in an accident before but I searched more on honda-tech and found that other people had the same problem, but it didnt make much sence to me still.
Old 09-25-2006, 02:28 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
With swapping the brakes from the teg, make sure the teg is non-abs and remember to swap the MC, booster and 4040 prop valve along with the spindles.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 09-25-2006, 07:44 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
don't we have a swap guide on this site?? if not, we need one
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-26-2006, 11:21 PM
thanks for the advice...and yea i had to bend the frame a tad for the other swaps as well....and yes the 'teg is a non-abs so im cool right. i sure hope so..thanks for the advice..could you let me know a little more about the master cylinder swap and such...or point me into the direction of some how to's thanks.
Old 09-27-2006, 12:49 AM
Heres a write up that should help..
http://www.fourthgenhatch.net/tegmp.html
Old 09-27-2006, 08:24 AM
Forunn Daberator
I posted pictures and listed what all to do when swaping spindles (all the tutorials (at that time... dont know about now) were only for swaping the entire control arm)
Old 09-27-2006, 11:19 PM
im sure we do somewhere, but no one on this site knows how to use the search function.
