Old 09-24-2006, 03:26 PM
Black97GST Black97GST is offline
O2 sensors??
Ok i had an acceleration problem previously (starting in second gear) and i replaced the VSS and it start in first now. How ever it does have sluggish acceleration and not much power it seems. It has a new exaust and one of the O2 sensors needs to be put on still (drill hole and weld a nut on). Would this cause sluggish acceleration / low power? Also how many O2 sensors should it have so i make sure it has them all? 94 S10 Blazer 2wd auto..... and yes my SES light is on (probably becuase of this).
Thanks,
Steve
Old 09-24-2006, 03:57 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: O2 sensors??
there should be 2 sensors. a bad O2 would hinder performance, in most cases making the engine overly rich. This is probably set off your SES light. get the code out of the computer and that will tell you what to fix. also if you have 4.3 with CPI, check to make sure that none of those components are leaking, which would cause similar symptoms.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-24-2006, 04:30 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Re: O2 sensors??
I would get that o2 on there asap. My buddy put a highflow cat and a flowmaster on a dakota r/t and it only had 1 of 4 o2 sensors on. the truck was just dumping fuel in the engine, he ended up frying his whole exhaust,(cat and muffler were glowing hot) and he put a big hurtin on the engine and tranny im sure
Old 09-24-2006, 09:15 PM
Re: O2 sensors??
so where are they located? so i know where to look to make sure it has the other one too.
Also, where is the EGR valve located. I wanna clean that.
Old 09-24-2006, 11:24 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: O2 sensors??
I am pretty sure there is only one on pre '95 trucks, its a heated sensor, just before the cat. There is no post cat sensor.
Old 09-25-2006, 02:57 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: O2 sensors??
Maybe it would be a good thing to say that what I told you do in the last thread about the VSS worked so people can gain some knowledge from it.
Kinda rude to accept the advice and just move on without even a thank you or allowing people to see that it worked.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2006, 06:23 AM
Re: O2 sensors??
So there is only one o2 sensor? Hopefully becuase thats all that he gave me with the truck. and you said it right before the cat?
actually i was gonna update and tell people that it worked, but i just want to make SURE it worked. Because im still having acceleration problems but (it seems) like it may possibly be starting in first gear now.
Old 09-25-2006, 05:51 PM
Re: O2 sensors??
Ok nevermind i found it on a different forum.......... there is one right after the Y and before the cat.
Old 10-27-2006, 08:11 AM
agcneo's Avatar
agcneo agcneo is offline
Re: O2 sensors??
would a bad o2 sensor make ur mpg drop signifigantly, somewhere around maybe 8mpg?
you may have a faster car.....but i can still drive over yours
Old 10-27-2006, 02:39 PM
BlazerLT's Avatar
AF -Advisor
Re: O2 sensors??
If you have a 1992-1995 Blazer it will be something else to cause that kind of a drop.
Old 10-27-2006, 02:52 PM
agcneo's Avatar
Re: O2 sensors??
its a 97
Old 10-27-2006, 11:57 PM
BlazerLT's Avatar
AF -Advisor
Re: O2 sensors??
1997......ouch....
Changed the ignition switch yet?
Old 10-28-2006, 10:56 PM
agcneo's Avatar
Re: O2 sensors??
yes i have, bout 7 months ago. any other ideas
Old 10-28-2006, 11:27 PM
BlazerLT's Avatar
AF -Advisor
Re: O2 sensors??
Ever done a tuneup?
Also, is your engine temperature getting up to near the middle mark on the gauge?
Also, how are you calculating your economy.
Old 10-30-2006, 07:20 PM
agcneo's Avatar
Re: O2 sensors??
yes i have done a tune up receiently, my temp bounces between the 150 and the 200 mark. it stays at 150 mostly, it will slowly climb to 200, then drop back to 150 fast. and incase you didnt see the thread i started " loads of blazer problems" my blazer sank in a pond when we were offroading, past the hood, and past the dashboard
