Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 09-24-2006, 12:11 PM
csl849 csl849 is offline
windshiel wipers
i have a 97 yukon wipers only work on high. is this the wiper pulse module or something else. thanks in advance.
Old 09-24-2006, 08:07 PM
bcopeland bcopeland is offline
Re: windshiel wipers
Sounds like the wiper motor is kaput!
Old 09-25-2006, 09:49 AM
i was hoping i wouldnt here that. that module is a good bit cheaper
Old 09-26-2006, 08:37 PM
LEsnow LEsnow is offline
Before you spend any money on a new motor check into recalls. My '96 was covered under a recall. The module developes a crack on the circuit board and the wipers start to act funny.
Old 09-26-2006, 08:45 PM
Very good point!
Old 09-28-2006, 01:14 PM
No such luck on the recall guess ill have to bite the bullet
Old 09-28-2006, 01:36 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If it is the module a drop of solder on the circuit board crack usually fixes them.
They usually crack where the power feed goes threw the circuit board.
MT
MT
Old 10-02-2006, 09:08 PM
Also, check your grounds. The motor housings are cast aluminum and where they connect to ground gets corroded. Disassemble them and clean them with sandpaper, etc.
