Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-24-2006, 11:33 AM
juggalojesus87 juggalojesus87 is offline
Lightbulb coolent line
i was wondering if there is any way i can take off the coolant hose that goes from the thermostat behind the engine and to the metel coolant line that goes to the raiator and replace the 2 hoses and the metel one with one long steel braided performance coolant hose
Old 11-21-2006, 11:42 AM
sexyfierobitch sexyfierobitch is offline
Wink Re: coolent line
wow juggalojesus you have more probs with your fiero then i do an i have alot lol.
but if you know how to fix an coolent line would you letme know mine has a hole in it an im bout to sell it want it lol.
Old 11-21-2006, 04:13 PM
Re: coolent line
stop right there do not sell your fiero just because you have a hole in your hose . just replace the hose... which one is it
Old 11-22-2006, 08:01 AM
Re: coolent line
lol i dont know thats why i wanna get rid of it. but hey i have a question you might be able to answer. you kinda remind me of ma husband. he likes fieros what should i get him for christmas lol. id be better off knowing doing this them shopping for him. lol thanx
Old 12-05-2006, 12:07 AM
scizzle scizzle is offline
Re: coolent line
What kind of fiero do you have? decide to sell it let me know. I used to have an '86 gt 5 speed. sexy beast. i miss it and kick myself for sellin it.
Old 12-05-2006, 03:26 AM
Jack_ink Jack_ink is offline
Re: coolent line
yes there is a way to replace the hose under the undercarraige (sp? Im tired) I actually just replcaed mine from front to back on both sides but the ones I used are ceramic coated (heat diffusion) high performance cooling lines... and if you want to sell a fiero you could also send me a line [email protected]
but replacing the line required the car be jacked up on stands so you can see under the car(mines dropped 3") when you stick your head under facing upwards you'll see the hose goes into a track with plates and bolts holding the plates up to keep your brake lines and coolant lines from scraping upon bottom out... as for braided lines if they are the rubber coated(inside) then they wont be as effective at the smart design of heat diffusion... I havent had a radiator fan since I had to install the summit racing camaro high capacity (3 or 4 core) and it was big enough I had to mount it at a 45 and use a firm piece of rubber to scoop air into it from the front aero nose for cooling power. although I am sure the braided(w/rubber insulation) would look really pretty
on another note I'll be getting the manufacterer's blueprints and schematis and parts # program soon from a body shop here but its only for the fiero's I'll burn you guys off a disk if you pitch in just to cover costs(blank disk envelope shipping) just send me an emailto the address above and I'll give you the details...
