Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 09-24-2006, 09:26 AM
mitchdakid mitchdakid is offline
98 TDI Jetta
Just purchased the car and now reverse and first and second will not work. It seems like it is going into 3 and 4 no matter where you put the stick when it is at the top or bottom. Even when you push it down and up to go into reverse it will still go forward like in 3rd. Any help would be gratefull.
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
Old 09-24-2006, 10:40 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 98 TDI Jetta
sounds like either the shifter bracket on the tranmsision is broken or the cables are way out of adjustment..
Old 09-25-2006, 08:11 PM
Re: 98 TDI Jetta
It was the transmission mount, now everythign is working except reverse. I have to push the stick down and up to get 1 if i jsut go up then it is 2nd. I think I just need to readjust the cable on the bracket but I have tried and tried and it will not work. Thanks for the start though I will see about the reverse.
1967 mustang coupe
