Old 09-24-2006, 01:19 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
possible to build a t5?
hey i found a free t5 by me and was wondering if itrs possible to build it to handle 500 hp and tq? will it be expensive? any one ever done it? thanks - Tom
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 09-25-2006, 04:06 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: possible to build a t5?
is it a world class? A regular one I don't think I'd waste my time on, I'll put ti this way, V6's break them fairly commonly. First 3rd gear goes... then 2 others... and by that point you rip it out for a (in your case) 700r4... if not even a th350/th400 :P
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-25-2006, 03:10 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
I don't think the newer (post 80's) manual factory transmissions are very easy to beef up. If it was a muncie I'd say yeah you could do it, but it'd be chaeper to buy a Richmond 5 or 6 speed, TKO500 or TKO600, or a D&D T56. By the time you have the original trans pulled, bought the upgrades for whatever you're working on, rebuilt that one and installed it, it'd probably be worth the extra 500-800 to buy a brand new trans... that works right and comes with a warranty.
If you have a stock ring and pinion (2.73 or thereabout) you'd probably be better off with a Richmond, they're designed to work with the numerically lower rear ends. I think the 5 speed is about 1900 and the 6 speed is about 2100. To get new gears, bearings, etc for a manual, if you're buying good quality new gears, will run you about $600 - $800. Figure you're saving about 5-20 hours depending on how many times you've done it (not hard, but first time is a bitch), and you might just be better off working a couple extra hours, maybe getting some overtime, and buying a brand new one.
My 2 ¢.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 09-26-2006, 02:26 AM
even the "built" t5's dont stand up to much power
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 09-26-2006, 08:42 AM
Earlsfat's Avatar
Cheesesteakoholic
Not according to the company that makes them: http://www.ttcautomotive.com/English...ts/TKO.asp#Car
The chart at the bottom says TKO should handle 500 ft/lbs. Now I know there's a big difference between a T5 and a TKO 500, but if you're calling a TKO 500 a built T5, then you're wrong. (At least on paper... I personally don't have any experience with them, and don't know anyone who deos either.)
Old 09-26-2006, 10:53 AM
well i have a th350 already in there. with a shift kit, i was just wondering about building a free t5 since all the holes and crap are there to switch to a manual cuz my car had a 5 spd in it at one time. i just wasnt sure if i could get it to handle my 400 when im done building it (which its in the hot tank right now at the machine shop my buddy works at and will probably end up being a 406 or something) and my rear has 3.83 gears i think???? maybe it is 3.86, dont remember. i will probably just end up doing a little more work on the th 350 like a trans brake and maybe a manual valvebody or the reverse pattern ones. and then drop a stall converter on it and put it back in. it sounds like i dont have the cash to go stick.
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 09-26-2006, 12:23 PM
T5 and TKO arent the same... how about instead of clicking on TKO, clickign on T5... http://www.ttcautomotive.com/English/products/T-5.asp
can't take more than 230 lb/ft...
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 09-26-2006, 02:29 PM
Earlsfat's Avatar
Cheesesteakoholic
500
Yeah I said that. By "built t5's" I thought you were refering to a TKO. I've never heard of anyone trying to beef up a T5... from what I've heard the cases are to weak, and it's not practical to make one stronger.
Anyhoo... If you're talking about beefing up a T5, not upgrading to a TKO... save your time, blood, sweat and tears. And money.
Old 09-26-2006, 03:49 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Get a doug nash 5 speed, those were the transmissions in the 350 Mecham Magnum Iroc-Z.
Honestly, save your money for a T56. They'll take the potentialof your vehicle to a new level. I want one...
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 09-27-2006, 08:17 AM
Earlsfat's Avatar
Cheesesteakoholic
I thought the only difference between a T5 and T56 was the second overdrive gear? (Performance-wise, obviously the T56 can handle more torque and HP)
