Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-23-2006, 11:53 PM
Ridleyj329 Ridleyj329 is offline
signal/hazard lights
these lights decided to randomly go out. what do you guys reccamend as far as getting them fixed?
Old 09-24-2006, 10:50 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: signal/hazard lights
are all the lights out or just one? do they work only as hazards but not turns or vise-versa?
just one light - check bulbs
only hazards or turns, not both - check fuses
nothing works at all - check flasher
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 09-24-2006, 10:54 PM
both the turn signals and hazards dont work at all. the other headlights do work. what fuses would i check?
Old 09-24-2006, 10:58 PM
there are two fuses one labeled TURN and the other HAZARD
Old 09-25-2006, 11:23 AM
while i was at school today these same lights decided they wanted to suddenly work. so now some times they do and sometimes they dont. which further adds to my confusion. if it makes any difference this all started when i changed my pass restraint track. the seatbelt light on the dash stayed on even when when all belts were locked. recently the door chime will go off when im driving and the belt light will flicker and off and on then stay on. my signal and hazzarda worked perfectly fine before that and now they work when they want to. would that make any difference?
Old 09-26-2006, 12:36 AM
it shouldn't, unless you damaged a ground or a section of wiring, but i don't have a wiring diagram handy to see how likely that is. in the mean time, wiggle any wiring near the area you worked to see if anything is affected.
