Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-23-2006, 10:55 PM
drdd's Avatar
drdd drdd is offline
pulling to the right
what would make my truck pull to the right? it pulls pretty noticeably ... more than like "I need an alignment" ...
I checked and regreased caliper slide bolts. Caliper piston seal is dry and looks good. There is nothing obviously rubbing the rotor. There is no noise whatsoever from the front end. No wobbling.
I've had it aligned, wheels balanced and rotated. Tire pressure is spot on at the recommended pressure.
any ideas?
Old 09-23-2006, 11:44 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: pulling to the right
Normal for the vehicle to always pull to the right seeing the roads always have a crown to shed water.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-24-2006, 12:04 AM
drdd's Avatar
yeah, true, but this is more extreme than that ... this is beyond normal ...
Old 09-24-2006, 02:26 AM
BlazerLT's Avatar
AF -Advisor
Take it back to the alignment shop.
Something is not right.
Old 09-24-2006, 04:45 AM
muddog321 muddog321 is offline
AF -Advisor
If not front did you look at the rear brakes - one sticking on right will keep dragging you that way - had a rear disc slide freeze and if 98up those rear caliper piston (single) get cocked in the bore after a brake job.
Old 09-24-2006, 10:05 AM
AChatham's Avatar
AChatham AChatham is offline
Have you checked your power steering? My dad had a similar problem with an old lexus. Not sure exactly what the problem was, Ill have to check with him, but be sure to check the power steering fluid.
Old 09-25-2006, 11:26 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I would say it is a blazer and to just get used it Actually my truck is in the shop so I have my moms 2000 and mine is a 98 and hers handles as far as steering and slopiness much better, rides better too, but mine with the upgraded shocks handles better and I can drive harder. I have never actually found out what she has installed except shocks that differ but hers stay as straight as an arrow
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 02-06-2008, 07:03 PM
Tanya71 Tanya71 is offline
One thing you might want to try is to swap the front tires side to side and see if the direction of the pull changes.If it does you need to replace some tires due to a shifted belt.You don't always have to have a shake or vibration to have a bad tire.
Old 02-06-2008, 07:12 PM
old_master's Avatar
Advisor/Moderator
We appreciate the help, but please check the date before you post in old threads. Thanks.
Closed Thread
