Need help with an electrical issue (Please..
I have a 91 Dodge Stealth RT that I recently bought. It appears that the previous owner did have an aftermarket stereo and security system in the vehicle before he removed them. Several things in the vehicle do not work. I am not receiving battery power to the stereo from the OEM wiring harness to the stereo. The power windows, power door locks, headlight motor, inside dome light, horn, and interior lights do not work. I checked all of the fuses at fuse box near the floorboard on the driver's side. Looking at the fuses they look okay. However, I cannot say whether the fuses and fusible link under the hood are okay. Can anyone help? I would appreciate it. Thanks.
Re: Need help with an electrical issue (Please..
Well the first thought that crosses my mind is hte ETACS computer (Electronic Time and Alarm Control System). It controls alot of that stuff, locks, windows, pop up lights, horn (i think). Not sure if it affects the stereo though. Anyway, it is located right behind your steering wheel. Lie upsidedown on your drivers seat, with your head near your brake pedal and look up, you should see it. It's held in by 2 bolts and has 2 harnesses.
www.stealth3000gtsalvage.com Should have one, just make sure you get it from the same generation and type of car. Probably any 91-93 DOHC NA, but double check that the serial nubmers match before you purchase one.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
you should call a Mitsubishi/Dodge dealership and ask them for the parts number for the ETACS unit for your year model of car.
searching google, i found a few part numbers for ETACS: MB852413 MB629054 here is an ETACS unit from a Mitsubishi Diamante http://cgi.ebay.ca/ws/eBayISAPI.dll?...ype=osi_widget . its probably similar to the one in the 3000GT/Stealth.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Thanks guys I really appreciate the help. Believe it or not it was a rather simple issue. The 120A fusible link had a hairline fracture in it. It was not noticeable to any of the mechanics that saw it. It was slightly discolored but not burnt, and I decided to check very very closely. Everything lit up that was supposed to light up and work. Thanks.
Awesome. Glad you found it
