Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 09-23-2006, 07:29 PM
95RSV's Avatar
95RSV 95RSV is offline
96 (Auto) Altima throttle problems
I have a 96 altima with an auto tranny. Everytime I will step on the accelerator a little harder than usually making the auto tranny downshift a gear, the throttle gets stuck and the rpm's keep rising until I tap the accelerator a bit harder to lower the rpm's to normal. I am pretty sure that the throttle switch located in the engine bay is stuck due to dried oil or it could be an electrical problem. I am going to use some wd40 lubrication to spray it down for now. I will update this thread if this problem arises again after to spray the wd40.
I the meantime can someone out there give me some advice.
thanks in advance
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Tokico HP Suspension
ADR DV8 Sandblack Rims
Nankang NS-1 Rubber
