Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-23-2006, 06:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Water Logging...
Hey all;
The other day I bought my boys CAI off that MX6 that got smashed. I took the piping and turned my short ram into a full CAI. It rained the last 2 days. I also drove out 40 miles and back to this training thing I had for work this morning. Anywhos, I was coming home flying at around 80 or so, and out of nowhere there's a huge puddle in the expressway. I was like whoa, but it was too late. I ran right through it. The engine bogged down and sounded like it was going to die for when it was in the water. After I got out, it fine. I took it a little slower for a while, but then picked it back up. Car ran perfect then. Was on the tollroad for about 6 miles or so so the engine was warmed up already.
Could this cause any damage? Also, it something like that does happen again, what should I do? Like stay off the throttle, or lay on it?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-23-2006, 07:28 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: Water Logging...
You might want to change your oil and pull your plugs.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-23-2006, 10:35 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I would say that going that fast, most of the water didn't have time to get sucked up. You should be fine. Next time, just lay off the throttle when you go over the puddle. I've gone through some pretty nice puddles with my CAI, and have yet to suck up any major water.
I second the oil change, plugs I would just pull and make sure they are good but probably not replace unless something was wrong with them.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-24-2006, 12:38 AM
ned032002's Avatar
ned032002 ned032002 is offline
Is there any way that someone can fabricate some kind of, idk drain so that in this situation if water gets sucked up, it falls into a small pit that just self drains once it gets so full. Is this idea retarded or what.
Old 09-24-2006, 12:45 AM
It's called a bypass valve...lol
They are a PITA to install from what I hear, and reduce what little performance gain you get.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-24-2006, 09:48 AM
david-b's Avatar
Dave is THAT guy
On my short ram, there's a little bung on it that had a pipe going to the stock exhaust DP. Since the DP don't have a piece on it, I just put a medium sized filter on it. It sits right above the EGR valve. I figure if some water is going on up intake pipe, some might fall into there. However, if you've ever felt the suction coming from the engine, it might not neither. I'll pull the plugs later today.
I ran the car all last night and it ran like a champ. No performance drop or anything. I have to change my oil sometime really soon anyways so that's ok. That puddle came out of nowhere, I swear...
75 Monte Carlo
Old 09-24-2006, 02:16 PM
ned032002's Avatar
Listen you...
Yeah I figured that someone would have created one of these, then I know that I had a good idea.
Old 09-24-2006, 04:23 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
1. ditch the CAI, not worth the risk
2. pull your plugs, are they wet? Replace them anyway and like someone said earlier change the oil if you can. You didn't hydrolock this time , but why would you risk it for 2hp and a sound.
now - 2000 civic
soon - 2002 is300
Old 09-24-2006, 09:20 PM
david-b's Avatar
Dave is THAT guy
I pulled the plugs today, and they were in perfect shape. No damage or anything. Actually, being 2 years old, they're in awesome shape. I cleaned off the contacts on the ends (all burnt up, apparently boot wasnt sitting fully flush on them) and the car actually idles better now. I will change my oil on Tuesday night.
The car really likes the CAI. I'm thinking of cutting the pipe and making it shorter. I mean right now its sitting right on the splash shield. Ill post a pic later. I'm jsut going to cut it shorter so its still low, but not that low.
75 Monte Carlo
Old 09-24-2006, 09:27 PM
david-b's Avatar
Dave is THAT guy
Really Low
75 Monte Carlo
Old 09-25-2006, 09:44 AM
Mine is about that low but I can't even see the filter, it's down by the horn.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-25-2006, 02:10 PM
david-b's Avatar
Dave is THAT guy
The horn is on the passenger side. At least mine is. Yeah, when I cut the pipe, I'm going to bring it up higher and angle it toward the front, so that the air flowing in through the grill can still get to it, since I have no foglights or foglight spacers. I'll probably do that tonight.
75 Monte Carlo
Old 09-25-2006, 04:14 PM
I'm almost positive it was the horn on the driver's side that I had to move to fit the filter...maybe they switched it from the 2ga to the 2gb? Oh well, IDK and it dosn't matter.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-25-2006, 08:42 PM
david-b's Avatar
Dave is THAT guy
Yeah... right?!?! Who cares. See, we don't need to fight over that like other people would. haha. On mine, the horn is on the passenger side in the bumper mounted to the bracket that the fog light attaches to. I took out the brackets (weight reduction and better flow) so I had to relocate the horn a little farther into the bay.
75 Monte Carlo
