Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-23-2006, 05:42 PM
joeshannallie joeshannallie is offline
!994 Bonneville Transmission
I been having problems with my car when I go to kick it down and go. It does not kick down. I changed the TPS and it still the same. So Advance finally told me that it more than likely was the 3 and 4th gear shift solenoid. Does this make sense? Does anyone know if it is hard to put in? Does the transmission have to be pulled? Please reply soon if anyone knows anything.
Old 09-23-2006, 07:42 PM
maxwedge maxwedge is offline
A990 racer
Re: !994 Bonneville Transmission
This problem should be looked at using a full trans function scanner for trans codes, solenoid operation and slippage errors, do not do anything prior to this diagnostic procedure. Advance is advising on trans problems, please!!
Old 10-01-2006, 10:39 AM
achevy4power achevy4power is offline
if none of that helps and you need a trans i have one out of a 94 boneville that i can sell
Old 11-05-2006, 06:03 AM
niptuckz28 niptuckz28 is offline
how much will you sell it for is this the non supercharged trans. where are you located.
Old 11-05-2006, 06:37 PM
Re: 1994 Bonneville Transmission
I am glad to say that I have fixed my problem. When I replaced the throttle position I put it on wrong. The throttle pin was suppose to be on one side of it and I had it on the other side of the sensor lever. So when you take something off it is best to take pics and everything else so you will know how it goes back.
Old 11-06-2006, 04:55 AM
that is good that you fixed the problem. there is nothing wrong with my tranny. always good to have one on hand.
