Old 09-23-2006, 04:01 PM
elYkYle07 elYkYle07 is offline
guages
Just a quick question, what brands and styles of guages is everyone using here, i.e. reverse glow, indiglow ect... Not for the main cluster but for anything after market i.e. boost guage, water temperature, oil pressure ect.
EDIT: Also are you happy with them and are they readable at night?
Kyle
currently working a deal on my car... 1994 3000GT VR-4, 12x,xxx miles, bone stock, pearl white, grey interior, paying 4,600!
Old 09-23-2006, 04:15 PM
youngcaradvc youngcaradvc is offline
Re: guages
do a search on google. To tell you the truth, I haven't found any real "options" for different gauges (reverse glow and styles) there might be some options, but aftermarket accessories are hard to find for our cars. check www.3sxperformance.com or wooddash.com, they might have some there.
Old 09-23-2006, 04:19 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: guages
If you want expensive ones, I'd go with Defi. Expensive, yes. But they are, from what I've heard, well worth the money.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 09-25-2006, 04:52 PM
Igovert500's Avatar
blue + red light magnet
Re: guages
Autometer are usually good. I think I'm using some cheap VDO something or other for my boost gauge. It works fine, lights up fine, but in retrospect I wish I had bought one that showed vacuum pressure as well.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-26-2006, 11:29 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: guages
i have autometer and spw, both acurate
Old 09-26-2006, 11:36 PM
Re: guages
i found the series i am going to go with, i want the auto meter full sweep electric ultra lite series, they will look nice, now i just need to figure out where i can get a dual guage pod for some 2 5/8" (66.7mm) guages, and i need to know if anyone has gotten them in the middle guage cluster...
kyle
Old 09-27-2006, 01:48 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: guages
i don't mean to sound like a smart-ass, but can anyone really tell if a gauge is accurate or not? isn't it just a ploy used by the manufacturer to get you to purchase their gauge? i'm sure every gauge manufacturer says something about "dead-on accuracy" regarding their gagues.
just an aside.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-27-2006, 02:18 AM
youngvr4's Avatar
STREET RACING GURU
Re: guages
good point, but ther reason i say that, is because i actually have two things reading boost
the gauge and the profec b spec II.....they read exactly the same and i tend to believe that the profec is reading dead on
the a/f ratio i dont know, but i do trust it
Old 10-03-2006, 08:42 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Re: guages
I would never use Auto Meter if my life depended on it... The quality of the guages arevery cheap and no they are not that accurate... I work for MVP Motor Sports and I've have seen and tryed out many guages. Some brands to stay away from is AEM, AutoMeter, and any other cheap crap...
Some of the most respected guage and most accurate is Greddy, Blitz, and Defi.
Defi is well worht the money because ot its unqique "Daisy chain" ability, maes installing guages very cleans and very easy, plus they look very good and are great quality, it has a mother controller that allows you to set warnings, peaks, and record. I overall payed $800... yes very expensive but like said earlier very well worth it. if you would like to see some of the different verities you can go here http://www.mvpmotorsports.com/Templa...855&SearchYN=N
But if you dont have the money to spend I would recomend useing Greddy guages they are not too expensive and very good quality guages, I used to own a set my self.
Upgrades... To many to list...
